Problem is that of the Dynadishes that are the hard nuts to crack (ie; not responding to Winbox as it’s disabled by the hack, http doesn’t work enough to get in, ssh and telnet turned off), there’s no remote access to work with. It’s interesting that some of these dishes, when presumably cut off from access to the mother ship by NAT degrade to cyclically rebooting every minute or so, and some others, seem to respond to a reboot and are nominally still running, even though they are infected.
BTW, what MT says about cleaning off the setup with a new one, absolutely true. Upgrading, changing passwords and rewinding the obvious stuff (second user “service”, turning off SOCKS) just results in SOCKS being turned back on, and in the case of one router (in a remote area, wireless interface, which makes it hard to clean remotely), it went right back to a state where it cannot be connected to.
Has anyone documented exactly what the hack does? Is it possible to expunge it completely without overwriting the device with a new clean restore file? When it comes to CPEs, the wireless interface precludes doing this remotely, as it’s MAC doesn’t match up with the MAC that the clean restore was generated on.
BTW, MT, feel free to jump in here. Perhaps some software to clean the attack off of infected devices?
Using the vulnerability described in the first post, somebody could get your password in clear text, if you had unprotected access to Winbox.
When the person has your password, there are any number of things he could do. The currently most widespread attack was by somebody who connected to such routers and added a SOCKS proxy configuration that runs some cryptomining script in your web browswer, when you hit a not-found 404 webpage.
To add to what @normis said - I’ve observed the same attack with SOCKS also attempting to send mass spam via port 25 (and only port 25) using From field in form of [random username]@[domain name from revdns]. The attack also added script and scheduler to run the script. Script was pointing at /mikrotik.php file, but as far as I can tell, it was empty. Possibly it was removed from attacker’s server before I managed to check it or it was not used yet.
Regarding the empty mikrotik.php … keep in mind that it’s a PHP which gets executed on web server. It could well be that the point of that script on server is to receive data about owned router and after it processes the data (the most important is router’s public IP address), it just returns empty page of type text/plain … so don’t get over confident just because local file seems to be empty.
Yes. Monitoring of active exploited routers is obvious (in fact there’s no even need for this to be PHP file, simple log analyzer would do the job), however the way script was made it could allow any commands from this file to be executed on exploited routers.
I have found some IP address of machine that was used:
IP: 95.154.216.151
aug/22 21:20:24 system,info,account user admin logged in from 95.154.216.151 via winbox
aug/22 21:20:24 system,info socks acl entry added by admin
aug/22 21:20:24 system,info socks config changed by admin
aug/22 21:20:24 system,info new script added by admin
aug/22 21:20:24 system,info new script scheduled by admin
aug/22 21:20:24 system,info,account user admin logged out from 95.154.216.151 via winbox
aug/22 21:20:54 system,info script removed from scheduler by admin
aug/22 21:20:54 system,info filter rule changed by admin
aug/22 21:20:54 system,info script removed by admin
IP: 198.100.28.129
aug/28 00:50:48 system,info,account user admin logged in from 198.100.28.129 via ssh
aug/28 00:51:12 system,info item changed by admin
aug/28 00:51:20 system,info item changed by admin
aug/28 00:51:27 system,info item changed by admin
aug/28 00:51:44 system,info,account user admin logged out from 198.100.28.129 via ssh
Think how much easier it would be to debug this if MikroTik logged all commands done on the router.
Please MT do like other network vendor, make all commands visible in the log.
On Cisco you can get it from AAA (Tacacs) that several has requested, or using syslog.
Currently heise.de writes about attacks on Mikrotik-Devices. Maybe you can correct something on the part of Mikrotik,
because the news does not sound good.
Hello Normis, I think I have read and understood all available information. Nevertheless, heise.de reports as if the security fix by mikrotik is at least questionable.
My post was not a complaint. I just wanted to point out this - possibly false - reporting.
