Winbox w3.40 Crashes evrytime.
Hello, i use winbox app to manage devices.
I am using pass manager included in winbox.
My issue is:
if i import about 3679 password records, winbox works until close.
When i want to start winbox again it crash ewrytime. I tryed to set it in compatibility mode, administrator start but nothing work.
Need to delete all stored address (in appdata) and import it again after winbox start. It is really annoying..
Hope someone help..
Have someone similar problem? Thank you.
There have been reported issues with winbox over the past several months.
If you take a look at the latest firmware just released 7.14, and the winbox fixes, it may be solved… ??
Thank you for answer. But I’m not sure that the version of RouterOS in individual routers has anything to do with the winbox application. The Winbox application does not even start to the stage where it can be connected to any device. Of course, most devices have firmware 7.11 and newer. But winbox still doesn’t start with imported accesses.
