Hi guys , here I have my new RB4011iGS+ box.
I configured it remotele over ssh.
Problem is accessing to graphic interface , neither winbox nor webfig finishes loading.
Webfig is stuked at “loading …” and winbox in “loading descriptors” message.
I already upgraded firmare to 6.45.9 (long-term).
And … don know what else to try , over same segment I have other mk device wich is working propperly.
Any idea to fix it ?
Regards.
Leandro.
You should open port 8291
I would recommend open it with Port knock
Sent from my SM-A705FN using Tapatalk
When I’ve seen similar behavior in the past, it seems like it tended to be an MTU issue to me. In your case of course it could be anything at all. You could have a firewall rule that is kicking in after some number of packets have flowed in the admin session, for example.
I’d start with a packet capture and take a look at how far it’s really getting. The data will be encrypted, but you might catch an ICMP unreachable indicating a possible problem. You may also be able to infer something from the encrypted sessions. It’s worth a shot.
Ethernet conector was no properly builded.
Regards.
