Winbox.. When will 3.x work properly?
Hey Mikrotik, can you spend some time on getting Winbox 3.x to work properly?
I would rather see that working than anymore ROS updates that tend to stress me out. :slight_smile:
Mind you, some good ROS updates, but I would rather not have to keep rearranging my Winbox window placements all the time. :sunglasses:
I just want “Load Previous Session” to work.
Well, that would be a small start… :confused:
You know how mikrotik answers : when it will be then it will be… I stay with v2 and it works good, just it should be able to reliably keep session layouts that it doesn’t sometimes.
