Winbox & WIN10 issue
I have upgraded form WIN7 to WIN10 couple days ago. Ever since i’m having strange issue with winbox, Some windows in winbox i can not see completely ( bottom part is under the taskbar), and there is no way to move/maximize it to be visible.
Well, here is the video: http://gfycat.com/WeeklyRealisticAstrangiacoral
I can not recall did i have a scrollbars on win7 but i know i didnt had this issue.
Resolution is 1366x768, my tasbar is 2 lines. Even if i restore it to default 1 line i still can not see some longer menus. IF winbox is not in fullscreen issue stays.
It is not windows related. Winbox does not have scrollbars. And yes currently it is an issue that you cannot see whole menu on smaller screens as well as some large dialogs with lots of properties.
what resolution is your screen set at in Control Panel? Also what size screen do you have
Its 15.6 inch HP laptop. Native resolution is 1366x768 which is set as display resolution also. Once again, i am 99% sure i didn’t have this issue on WIN7. Tnx for replys, guys.
