Hello, guys,
Recently after updating to 3.22 of the winbox I found that every time I log into winbox my windows position and size is displaced. I’ve tried to save the session but without any success. Every time I log into the windows are expanded and on a different place, so I have to arrange them every time. Is anyone experience similar problem? I didn’t had it previously.
Idem, I have the same problem. Had to downgrade to the prior version of WinBox.
I think the only way is to have the old version .exe saved somewhere. It may happen to be a bug in the current winbox version and it is utterly annoying.¶
Hi, I have the same issue. After logging to ROS window is weirdly small. Look at images.
