Winbox Wireless Scan/Connect with API
Hello all,
I’m kind of a begginer in this MikroTik scripting world but i would like to be able to replicate Winbox’s functionality, that is:
Wireless Scanner → get a list of SSIDs, select one and click Connect and the SSID is set for wlan1.
I’ve tried using this:
var commands = new List() {
“/interface/wireless/set”,
“=.id=wlan1”,
“=address=” + ap.Address,
“=ssid=” + ap.SSID,
“=channel=” + ap.Channel,
“=radio-name=” + ap.RadioName
if(ap.SNR.HasValue)
commands.Add(“=snr=” + ap.SNR.ToString());
if (ap.Signal.HasValue)
commands.Add(“=sig=” + ap.Signal.ToString());
if (ap.NF.HasValue)
commands.Add(“=nf=” + ap.NF.ToString());
//if(!string.IsNullOrWhiteSpace(ap.Section))
// commands.Add(“=.section=” + ap.Section);
// End sentence
But i don’t see it doing anything. Not sure if it this is even valid code or api commands.
Does it have something to do with connect-list?
I’m sorry if this question has been asked and answered before, i’ve tried searching but couldn’t find anything.
Thank you!
I did it :slight_smile:
The problem was i ran interface/wireless/scan command before to get the list of SSIDs.
This continued working in the background and it (probably) kept messing up my communication with the api.
So i had to run Write(“/cancel”); Read(); before doing:
“=ssid=” + ap.SSID,
“=.id=wlan1”,
await Write(commands);
var data = await Read();
Also i thing that “=.id=wlan1” has to come last after all the other commands.
Hope it helps!
Kind regards,
Can I see your whole source code?
I’m doing something similar to your code,
or just email to me @ martin_kolsawala94@yahoo.com
your code will be a huge help.
Thanks,
