winbox wont accept me from wireless
Hello there
this is ths 3rd time to asking for help in this issue
WHEN I LOG FROM THE LAN BY THE WINBOX . IT IS OK
I LOG AND WORKING FINE
BUT WHEN I TRY TO LOG FROM THE WIRELESS NETWRK
I CAN’T LOG TO THE ROUTER BOARD OR THE MIKROTIK SERVER
so plz if any port or anything closed
just tell me the how i open it or what is this issue
we need more information, and you are not giving us any!
can you ping it’s IP? can you telnet into it? if no, probably the IP addresses are wrong. Paste “/ip address print” and “ipconfig” from windows.
i can tell net to both of them
but i can only enter the mikrotik server
because the RouterBoard asking me for alot of password . not only one
and i can ping to the IP of the Server and it’s replay me , Normaly
but the problem with the winbox
i can’t use it from the wireless network
the problem is definitely not in winbox but in your router config. why can’t you telnet to it?
when i telnet to the ROUTERBOARD . it asking me for alot of password
not only ONE TIME
and i want use the WINBOX to use my server
and i can give u any info aboutg the config but just help me plzzzzzzzzz
I don’t understand you :slight_smile: what you mean by “a lot of password, not just one” ???
paste some screenshots, we can’t guess your problem. we need to see it here
i meant. when i try to log to the ROUTERBOARD . it asking me for the password direct
not even the user name
and after i type the password
and asking me for another password
then another password
3 times
and this connection lost :smiley::smiley:
man i need to use the WINBOX from my wirless network . this is the real problem
Somehow I think you are not connecting to RouterOS, maybe you configured bridging and it’s some other device you have reached. what is your setup in the router? is it bridging? or you made some NAT rule?
try password ‘1234’ ))) or ‘admin’ :slight_smile:
