Hi ,
any chance of adding some free form pick boxes ( to fill additional informational columns) to the WInbox Main Start Window ( Select Device) and Also “Dashboard” display once you have selected the Router only has a few Elements that may be selected .
At the Moment you can see Mac Address IP Address Board , Name, Version etc ( Would like to see the current running Firmware Version ) ( If there was a Selection Box you could enter a variable/ status so that you could select any relevant status to be displayed instead of the small list like there is at the moment )
Any Chance of Adding a Select ( Option tick Button) in Winbox/System/Routerboard to Enable/Disable Firmware Update whenever the version is changed
Also you could potentially start Software Firmware Updates then by selecting a group of devices in Winbox if an option was available
Cheers Jason
