Existe alguma previsão de sair alguma versão do winbox para MacOS?
Not likely,
quick check I found these…of course use at your own risk.
http://joshaven.com/resources/tools/winbox-for-mac/
https://www.codeweavers.com/compatibility/crossover/winboxexe
https://appdb.winehq.org/objectManager.php?sClass=application&iId=1881
A post from Normis…
in this thread…
**http://forum.mikrotik.com/t/macos-catalina-ios-catalyst-swiftui-wine/133779/1
While you are waiting for the new 64bit exe file to be released soon, you can already prepare your macOS catalina systems according to these instructions:
If you have used Wine previously, we recommend you first delete the previous Wine application and the Wine settings directory in your home folder:
rm -rf /Applications/Wine*
rm -rf ~/.wine/
To run Winbox64 the following steps are required.
Install Wine Staging from WineHQ official download page https://dl.winehq.org/wine-builds/macosx/download.html
and make sure you have downloaded the winbox64.exe executable from the MikroTik download page.
During installation, you must mark “64 bit support” (by default it is not checked).
In macOS terminal, make sure your set to use ZSH as the new shell like this (and restart Terminal after this command):
chsh -s /bin/zsh
Edit your zprofile file to add environment variables, pointing the wine64 command to the correct installation path of Wine Staging:
nano ~/.zprofile
The file should look like this (make sure your paths are correct here):
export PATH=“/Applications/Wine Staging.app/Contents/Resources/wine/bin:$PATH”
export FREETYPE_PROPERTIES=“truetype:interpreter-version=35”
export DYLD_FALLBACK_LIBRARY_PATH=“/usr/lib:/opt/X11/lib:$DYLD_FALLBACK_LIBRARY_PATH”
Restart (quit and reopen) your macOS terminal
Launch Winbox64 with wine64 like this:
wine64 “/Applications/winbox64.exe”
Thank you.
Is there anyway to make a “shortcut” that I can place in dock?
