I have the 2.9beta16 installed on the RB500 that I just received.
This is my first time on 2.9
I try to enter via telnet, and this is ok.
But when trying via winbox (the one I use on the 2.
I receive an error: cannot connect to port 8291.
where is the problem ?
thanks
Gianluca
and also when connecting through the serial cable, I can see the system start up, launching services but then I dont receive on my teminal screen any login… but at the same time if I try to enter via telnet it works.
if someone has any experience on it???
thanks
You need to download and use the new version of WinBox from the router.
Regards
Andrew
I have been looking for it for a long time, but from where can I download the winbox?
http://<router_IP>
that should pull up the mikrotik splash page where you can download winbox.
many thanks. now i have it and it works.
Gianluca
