WINBOX
is there some sort of customization that I can do on winbox?
I’d like to have a winbox customized but I dont want to develop one from the start
somebody help me
no, there isn’t
thank you.
may I have winbox source code so I can change it?
is winbox an open source?
No, it is not. The source code is not available.
Take a look at instead using the API. There are existing libraries for interacting with the RouterOS API in quite a few languages. It is quite powerful.
Aaron out.
Just one more question;
Using API routerOS, can I set all network interfaces IP?
I don’t have to implement all winbox functionalities.
Can I implement only the issues I need?
Thank you all.
Yes.
