Winbox
I have done a PC install and everything seemed ok,but cannot get winbox to logged in.Anytime I tried using Winbox to connet to the routerOS I get error,no winbox pluggin.Where can I get this pluggin to install on this box to enable me use it.
Please, make sure you have the latest MikroTik RouterOS version installed on the router.
It should be 3.30 or 4.4 version (check by /system package print).
Download the latest Winbox as well (it is available at demo2.mt.lv).
Winbox should work after it.
