winbox
we are not able to see configuration while using winbox but it is shows when we login in GUI with same user name and password
What screen see you on your screen? printscreen pleace
If you mean that Winbox doesn’t show config, and Webfig does, make sure that you use the IP address in Winbox, not MAC. MAC address communication is often slower than IP, and configuration can take a while to load.
