Winbox3.0 released!
What’s new in v3.0:
*) do not reset user name & password when one of the routers is selected in neighbours list;
What’s new in v3.0rc17:
*) discover older version RouterOS routers and SwOS switches as well;
What’s new in v3.0rc16:
*) fixed problem where it was not possible to connect to router through RoMON if
Open in New Window was enabled;
What’s new in v3.0rc15:
*) make “Install & Upgrade” button work again;
*) fixed crash when typing Ctrl-D in empty terminal window;
What’s new in v3.0rc14:
*) show properly advanced mode on start up;
*) make console use whole terminal window width on reopen;
What’s new in v3.0rc13:
*) allow to specify RoMON agent via command line;
*) fixed window size when Winbox is opened first time;
What’s new in v3.0rc12:
*) added “clear cache” command to Tools menu;
What’s new in v3.0rc11:
*) fixed session saving;
*) move cursor to password or login field when host is selected in address list
or in neighbours
What’s new in v3.0rc10:
*) remember first window size;
*) fixed crash when trying to connect to the router;
*) fixed connecting by mac addresses on Windows with multiple network
cards (needs at least RouterOS v6.29 on the router as well);
*) added back keyboard short-cuts for tables (INS for add, DEL for remove
and all other with Ctrl prefixes);
*) added support for Shift+Ins, Ctrl+Ins, Shift+Del short-cuts in text entry fields;
*) fixed crash when connecting to v5 routers;
*) fixed problem where group column contents were not shown;
What’s new in v3.0rc9:
*) added advanced mode;
What’s new in v3.0rc8:
*) added RoMON support;
*) show default values in CAPsMAN settings;
*) fixed crash when reopening ping or profile window;
What’s new in v3.0rc6:
*) allow to in-line comments per table bases as well;
*) remember table filters in current sessions;
*) remember Torch window column sorting order & visibility;
*) by default hide all passwords;
*) remember that session was on reconnects;
What’s new in v3.0rc5:
*) fixed problem where active session was not loaded immediately on connect;
What’s new in v3.0rc4:
*) fixed problem were secure connections when opening in new window were not closed;
*) fixed problem when in-line-comment added comment column
where no comments were allowed;
*) added save session to Session menu;
What’s new in v3.0rc3:
*) fixed problem where in-line-comments setting to affected only visible tabs;
*) allow to move session file folder;
*) allow to choose session file from any place;
*) fixed embedded table size;
What’s new in v3.0rc2:
*) allow to make object list windows smaller;
*) support connecting to v5 routers with “Open In New Window”;
*) do not save last session password if address list is encrypted;
*) fixed problem where “open in new window” didn’t work;
*) fixed crash on session save;
*) fixed crash when opening ip web proxy access window;
*) handle correctly sessions that have ‘:’ in their names;
What’s new in v3.0rc1:
*) made global setting for comment in-lining;
*) added session management;
*) added ability to connect to multiple routers at once;
*) added ability to save address list in another place;
*) added ability to encrypt address list file;
*) fixed Dst. Address filter in ip routes;
*) make Winbox work with TeamViewer;
*) report connection & disconnect status in-place;
What’s new in v3.0beta3:
*) make log table show last entries automatically;
*) fixed problem were changing managed entries made them disappear;
*) when sorting by groups in-line category headers as well;
*) added “New Winbox” button;
*) fixed crash when opening tools|profile;
What’s new in v3.0beta2:
*) fixed problem where Winbox crashed if Wirless-fp package was installed on the router;
*) fixed problem where Winbox crashed if Activate button was pressed in Stores menu;
What’s new in v3.0beta1:
*) implemented self upgrade;
*) added ability to open new session in new window;
I still have serious issues of missing menus with 5.x versions.
I deleted the whole data into the %appdata%\Mikrotik\Winbox\ folder. The first time I open a version 5.x routeros, menus are there. The second time, I have missing menu items (Wireless, PPP, Routing)
It’s unusable for everybody has versions 5.x and 4.x
It’s the same problem that I am having since versions > RC3
To me, when I connect to a <6.x version I get the old winbox 2.x interface.
No missing menus for me.
Also connecting to older versions it remembers on which of my monitors the window was last loaded (standard winbox 2.x behavior).
But connecting to 6.x versions it will always load the window in the same monitor as the winbox loader which is very annoying.
Please make winbox remember on which monitor its session should be started.
Just wanted to ask: in 3.0rc2 for example I was able to set “Notes” and “Group” for each entry in “Address list”. In latest 3.0rc and in 3.0 release I see no such a field, but it display notes for old entries.
Here is the example from 3.0rc2: http://prntscr.com/90h17z , here is what I see in 3.0 release: http://prntscr.com/90h1ry (note there is no Notes and Group fields at all)
Any chance to display these fields again?
You need to enable ‘Advanced mode’ to show those fields.
Click on Tools > Advanced Mode and should be ok.
Is recognized by AVG 2016
You should click on the button that reports a false positive.
how do I add am image to show the missing menu items when opening WinBox v3.0 with rOS versions lower than 6.0?
I am missing allot of menu items and have to run 2 different versions of WinBox and that is annoying.
Use the ATTACHMENTS option when posting in the forum:
Missing menu options.
Please see screen shots
We finally managed to reproduce missing menus issue. It is reported to our developers. It will be fixed as soon as possible. if you will not use “Open in New Window” option, then it should work just fine.
Thank you for this, and yes that does work.
That feature is very handy and I hope you are able to fix it soon.
Once again, thank you.
Guys, PLEASE, sign digitally Winbox executable. There are so many malware programs out there today and since your products are used on a very large scale, you are the target for criminals.
You can get Microsoft Authenticode Certificate based on at least SHA-256 at very resonable price today. Please, do this for the the safety of your customers and your business.
And it would be also nice to put SHA-256 hash instead of MD5 on download site. PGP signature and HTTPS access also would be very nice.
Thank you very much.
Hi, good day. when i use winbox 3 selecting “open in a new window” logins in unsecure mode (ROS v5), when i unselect “open in a new window”, it logins in secure mode. In ROS v6 is secure both modes, thx
Any uptade to use winbox 3 on rOS 6.33 on a Mac?
Thanks! :slight_smile:
For Mac, you can donwload from http://forum.mikrotik.com/t/winbox-on-os-x-10-11-el-capitan-its-a-way-to-fix-it-the-easy-way/91807/1
open the package, and replace winbox.exe with new version :smiley:
works fine.
Or you can download from the manual. MacOS and Linux Winbox can also update themselves when you click “Tools → Check for update”. You don’t need to download again.
I’m having issue MAC telneting into routers with this version of Winbox. 2.2.18 does not have this issue when run side by side.
Really Amazing news for me,
Thanks ,
I like to use this one :slight_smile: good work!
Found only one small thing: if you have one instance of Winbox and connected to multiple devices through “Open in new Window”, then if the connection is lost to multiple devices, you have multiple “Router has been disconnected ago” windows with different “Connect To” but with the same “Note” field even if it was different saved entries with different “Note”.
