Winbox3.3 released!
What’s new in v3.3:
*) added back ‘Exit’ button;
*) show all managed entries on Reconnect failure;
*) make mac winbox work more reliably (makes possbile to connect to RB850);
*) make RoMON work with RouterOS older than v6.35.
If you experience version related issues, then please report them to support@mikrotik.com.
Winbox is available here:
http://www.mikrotik.com/download
If you try to upgrade directly from Winbox loader and version is not available, then you might need to wait for a while until cache in path between your device and our servers is refreshed.
very fast…
I think that’s an understatement :laughing:
nice… keep the good work :smiley:
Just small note: Maybe you can add higher resolution app icon… :sunglasses:
Real fast!!! kudos!
Quick work !! :slight_smile:
Windows Smartscreen does not like it though - reports it as an unrecognised app from an unknown publisher on Windows10. You have to force Windows to run anyway…
If you pin it on taskbar, you will have it with a good resolution :wink:
thanx for bringing back romon compatibility with older ros
Thank you guys!
Guys, PLEASE, take one hour study in today’s cryptography and SIGN WINBOX EXECUTABLE (Microsoft Authenticode) with AT LEAST SHA-256 function, or dual-sign with SHA-256 and SHA-1 for compatibility (like Windows, WinRAR and other today’s software does).
Your software is used in very sensitive environments, so security must be on very high level.
AT LEAST attach checksum on the website, but not with old-fashion, compromised and totally obsolete MD5 function, but with SHA-256 AT LEAST. sha256sum, sha256deep, HashTab, Total Commander and even PowerShell can do this.
THANK YOU SO MUCH
Also see: http://forum.mikrotik.com/t/winbox-3-rc/84760/324
+1 :slight_smile:))
ok, now it seems MT is working on the winbox platform again ince years without… I have one other, very annoying item, I’d like to discuss and see if it is open for improvement.
I seem to remember in the ‘early’ days, when I changed anything in the ‘connect to’ list, or the ‘access’ list of a wireless interface the object (CPE) did not disconnect each time a change or edit was applied…
You just could change a name in the comment field for a unit in the accept list and apply while the unit itself just stayed connected to the AP radio.
Now this was in the days before NV2 and mimo technology…
But in fact it always irritated me that since then units disconnect for every little alteration we make in a list.
For instance, in access lists of AP’s we mention an antenna (CPE) number, the clients name, type of antenna, signal of 1st connection (installation) and contract type. So in one eye stroke of the registration table of an AP we have all the most important data and inmediately available.
But to get a nice looking winbox overview we need to align the texts in columns and correct typo’s, sometimes change contract, or client name, or type of antenna etc.
Since alterations are only visible in the registration table after the change is made in the access list and both are not visible at the same time to align all date properly you have to flap between windows all the time and each time make a new edit, apply it, go back to the reg. table, see if it is ligned out now, if not, go back to the access list, edit and apply again, etc. etc. etc.
Each time you apply the unit disconnects… even if def. auth in the AP is enabled!
(Same in the ‘connect to’ list in the CPE. If an edit is applied to that list, even if def. auth is enable, the unit still disconnects)
Why would a CPE being forced to disconnect (and inmediately re-connects again) if only a text field in a comment label of a listing in the access list is changed???
I’d remember for sure in the old days this was not the case…
Is this something that can be correct / improved in a new winbox version?
This sounds like feature request for new wireless-rep package not winbox, now when any card can work in 2 modes at the same time and even scan and snoop without disconnecting clients i think adjustment in connect and access list shouldn’t disconnect users also
. i think you need to write this feature request to support
In model of “hAP lite (smips)” there are no data
Awax - Do you use Winbox 3.3? This is problem from older version Winbox.
please make winbox (windows) fully portable. something to be like the screenshot below in my external harddisk. why is necesary to search in %appdata% to find files of winbox.
all the files of winbox in current folder!
the problem with current folder is that view files does not be transfered and we have to look at %appdata% folder
Winbox V3 problem including V3.3:
Look at the picture, at my screen size 1280x800px, in Wireless - Advanced Mode window size too long. How about smaller screen pixel size such as notebook PC 1366x768 or netbook PC 1024x600? How can we set?
Imagine if all buttons and info located at title bar (such as firefox/chrome). Sure we can have more space to work with.
Or if can’t do that, please provide scroll bar/button. Thanks.
Hi
Когда появится возможность изменять размеры полей в логе?
When there is an opportunity to change the sizes of fields in the log?
It seems, promised to return in release.
Yes version 3.3
