hello,
I have RB750GL router. My windbox on PC can’t find my Mikrotik router.
- If I plug the Mikrotik directly to the PC, everything works well.
- If i plug another router between PC and Mikrotik, I can see IP address is set and I can ping the Mikrotik
When I try to connect the Mikrotik using windbox, router’s Led blink once, but windbox cant access it…
I did checked another router’s setup and didnt fint any problem. The firewall on the PC also disabled…
Any ideas please?
Petr
