The one thing that upsets me about The Dude, is that the close window button is on the far right of the window. We run the Dude from
a server at our colo facility from VNC. The combination seems that the
close window button is never clickable, despite stretching or changing screen resolution. I dont know whether this is VNC or a combination of the display factors. Could we have the position of the close x shifted to the left of insert on button..
I wish! Under VNC it seems to sit just under the right hand scroll bar.
Sometimes it is easily visible but mostly I cant just get to it.
The other three or four buttons are fine, but it is very frustrating when
trying to close the window down. If I stretch it, then the right hand border
stays constant.. while everything else stretches. Then there is a small edge sometimes to click.
Kenk
As usual with computers my screen capture program is crashing my VNC. It only happens when there is only one window displayed - for example with two windows both close x’s are displayed. Close one down
so the remaining one is full screen and in resizing it shifts to the right
hiding the x under the VNC scroll bar. I’ll persevere with the screen capture. Thanks.
