Windows 7 Ikev2 Split Include
I set up an Ikev2 server on Mikrotik. All clients connect without problems, but the transfer of routes to Windows 7 does not work. Someone faced a problem, can it be made to work?
Q1. Do you use Windows VPN-Client or a 3rd-Party software to connect via Ikev2?
Q2. How do you know the Routes are not working? (Windows CLI : route print)?
Q3. Can you please POST your config ? (/export hide-sensitive file=anynameyouwish)
1.VPN is installed by standard Windows.
2.I attach a Screen
3.Took everything about Ipsec
/ip ipsec policy group
add name=IKEv2-group
/ip ipsec profile
add dh-group=modp2048,modp1536,modp1024 enc-algorithm=
aes-256,aes-192,aes-128,3des name=IKEv2-profile-ph1
/ip ipsec peer
add exchange-mode=ike2 name=vpn.it-russia.com passive=yes profile=
IKEv2-profile-ph1
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=
aes-256-cbc,aes-256-ctr,aes-128-cbc,3des lifetime=1d
add auth-algorithms=sha512,sha256,sha1 enc-algorithms=“aes-256-cbc,aes-256-ctr
,aes-256-gcm,aes-192-ctr,aes-192-gcm,aes-128-cbc,aes-128-ctr,aes-128-gcm,3
des” name=IKEv2-proposal-ph2 pfs-group=none
add address-pool=VPN-ike-pool address-prefix-length=32 name=client split-dns=
its.local split-include=10.1.84.0/24,172.16.0.0/24,172.16.253.0/24
static-dns=10.1.84.5,172.16.0.10 system-dns=no
/ip ipsec identity
add auth-method=eap-radius certificate=vpn2.it-russia.com generate-policy=
port-strict mode-config=client peer=vpn.it-russia.com
policy-template-group=IKEv2-group
/ip ipsec policy
set 0 disabled=yes
add comment=“IPSec policy for vpn pool” dst-address=192.168.137.0/24 group=
IKEv2-group proposal=IKEv2-proposal-ph2 src-address=0.0.0.0/0 template=
yes
add comment=“Policy to IPSec clients from ALL” disabled=yes dst-address=
192.168.137.0/24 peer=ipip-cod-vr-cn proposal=IKEv2-proposal-ph2
src-address=0.0.0.0/0 tunnel=yes
/ip ipsec settings
set xauth-use-radius=yes
Windows 10 Works seamlessly.
I also noticed that when I connect to Peers on Mikrotik Src, I see my internal local subnet and not 0.0.0.0/0. There is a Screen
Windows 7 does not support the Split Include option.
You have to add persistent routes manually.
i think any windows doesn’t support the Split Include option.
For windows i’m using open vpn, that allows you to do that
No, as stated, Windows 7 does not support IKEv2 split include. Rest of them work fine (newer than Windows 7).
