Wired WDS?
Ideal: Wired Mesh feeding wireless radios.
We are looking to use ethernet between several MT hotspot radios( using dynamic WDS Master/Slave type of setup so same essid can be used on all radios) so that performance is not impacted by using wireless as the back channel. Is this something that can be accomplished using current software or does this need to turn into a feature request?
Thanks!
MikeB
Simply Bits.
just use bridge.
