Wiregard conntextion to opnsense
iam new at this forum and mikrotik.
I have an LtAP LR8G LTE6 kit that I use as a LoRaWAN access point.
It already works. LoRaWAN packets are received and transmitted to the internet via LTE.
To make it easy for me to access the router's administration, it should connect to my opnsense via Wiregard.
I've already managed to do that and the Wiregard connection is established, but i get no connection to the Mikrotik Web Administration.
But I'm currently struggling with the firewall and routing rules on the opnsens and the Mikrotik, so that I can access the Mikrotik (web administration) from my LAN via opnsense and wiregard.
The Mikrotik should not send any data via the Wiregard connection (except, of course, the web administration).
Lora data and other things should use LTE and the Internet as normal and not be routed via the Wiregard connection.
LAN1 - opnsense (25.7) - Wiregard - Mikrotik (7.19.3)
Can you help me and possibly give me detailed tips on what I need to configure on Mikrotik and opnsense so that I can access the web interface?
Many Thanks,
Oliver
