wireguard and activity logging
Quick question. I have setup wireguard for roadwarrior setup.
Now I would like to do some activity logging: get a syslog message when:
a) a peer tries to connect (successfully, unsucessfully)
b) disconnects.
c) etc.
I think ovpn already is a log topic as mentioned here: https://help.mikrotik.com/docs/display/ROS/Log
. How about wireguard or did I overlook something ?
I use /Tools/Netwatch to ping an unique IP address on the other side of the WG connection.
Then I see connects and disconnects and a on/up script then log those events.
In Mangle you can route the ICMP to the correct tunnel.
Hello, thank you.
however, using your method: how can i log whether somebody tried to authenticate to wiregaurd (successfully, unsuccessfully?)
from what i understand from you the feature (logging) id not part of routeros now. should i post a feature request for htis somewhere ?
tobias.
