Will Wireguard server be able ever to authenticate a client by a call to a radius server?
Is there a way to see which clients are connected to the server like the active connections in the PPP?
it would be nice to be able do authentication by using radius server ![]()
Could Capsman be coerced into supplicating for the wireguard wg0 tunnel?
I don’t think so, WG does not have AUTH(username/password), and you cant push the IP pool to clients. static IP only.
you can use IPsec IKEv2.
