Hi All,
Long story short: after a few years with hAP ac2 I deicided to dive deeper into networking and bought an RB5009 to expand my network to 2.5G, learn VLANs and use pihole now in the router not in a separate machine.
I successfully set up the router and the AP for VLAN (using the examples provided by the forum) but I cannot get the Wireguard working. To be specific, I can connect to the wireguard endpoint and I can see traffic goes from the wireguarded ip but it never gets answer even for a simple DNS query to 1.1.1.1.
I was using wireguard with my hAP ac2 until I got the “bigger” router and implemented the same firewall rules (and more) in the RB5009 but something is still missing or misconfigured. I suspect the problem near the bridge and the lack of DHCP on the bridge (eg a 2.5G unifi device is not getting any IP but marks and flows the traffic just fine and this applies to the hAP ac2 too).
Could someone help me where could be the problem or what concept should I research to understand the issue?
FYI: I know I possibly went over and beyond with the current VLAN config but it is only the first iteration. My original design sounded better in my head then seeing it in “production” now.
Example firewall log
2025-06-02 21:56:19 firewall,info forward: in:wireguard-main out:ether2, connection-state:new proto TCP (SYN), 192.168.30.101:55222->108.141.16.127:443, len 64
2025-06-02 21:56:19 firewall,info forward: in:wireguard-main out:ether2, connection-state:new proto TCP (SYN), 192.168.30.101:55221->13.107.246.44:443, len 64
2025-06-02 21:56:19 firewall,info forward: in:wireguard-main out:ether2, connection-state:new proto TCP (SYN), 192.168.30.101:55223->142.250.201.194:443, len 64
2025-06-02 21:56:19 firewall,info forward: in:wireguard-main out:ether2, connection-state:new proto TCP (SYN), 192.168.30.101:55225->69.173.144.138:443, len 64
2025-06-02 21:56:19 firewall,info forward: in:wireguard-main out:ether2, connection-state:new proto TCP (SYN), 192.168.30.101:55224->69.173.144.139:443, len 64
2025-06-02 21:56:20 firewall,info forward: in:wireguard-main out:ether2, connection-state:new proto TCP (SYN), 192.168.30.101:55227->142.251.208.162:443, len 64
2025-06-02 21:56:20 firewall,info forward: in:wireguard-main out:ether2, connection-state:new proto TCP (SYN), 192.168.30.101:55226->142.250.180.196:443, len 64
2025-06-02 21:56:20 firewall,info forward: in:wireguard-main out:ether2, connection-state:new proto TCP (SYN), 192.168.30.101:55228->69.173.144.165:443, len 64
Sanitised config:
# 2025-06-02 21:57:43 by RouterOS 7.19
# software id = D53G-786U
# model = RB5009UG+S+
add name=bridge protocol-mode=none vlan-filtering=yes
set [ find default-name=ether1 ] comment="2.5G Network Unifi"
set [ find default-name=ether2 ] comment=WAN
set [ find default-name=ether3 ] comment="Mikrotik hAp ac2"
set [ find default-name=ether4 ] comment=dev
set [ find default-name=ether5 ] comment=unused
set [ find default-name=ether6 ] comment=nvr
set [ find default-name=ether7 ] comment=unused
set [ find default-name=ether8 ] comment=unused
set [ find default-name=sfp-sfpplus1 ] comment=unused
/interface wireguard
add listen-port=51820 mtu=1420 name=wireguard-main
/interface vlan
add interface=bridge name=vlan10-main vlan-id=10
add interface=bridge name=vlan11-restricted-main vlan-id=11
add interface=bridge name=vlan20-phones vlan-id=20
add interface=bridge name=vlan30-wireguard vlan-id=30
add interface=bridge name=vlan40-dev vlan-id=40
add interface=bridge name=vlan50-server vlan-id=50
add interface=bridge name=vlan60-nvr vlan-id=60
add interface=bridge name=vlan70-cameras vlan-id=70
add interface=bridge name=vlan80-iot vlan-id=80
add interface=bridge name=vlan90-guest vlan-id=90
add interface=bridge name=vlan99-mgmt vlan-id=99
add name=WAN
add name=VLAN
add name=LAN
add name=MGMT
add name=PREVENT_LAN
add name=BASE
add name=WIREGUARD
add name=main-pool ranges=192.168.10.10-192.168.10.100
add name=phones-pool ranges=192.168.20.10-192.168.20.100
add name=wg-pool ranges=192.168.30.10-192.168.30.100
add name=dev-pool ranges=192.168.40.10-192.168.40.100
add name=server-pool ranges=192.168.50.10-192.168.50.100
add name=nvr-pool ranges=192.168.60.10-192.168.60.100
add name=cameras-pool ranges=192.168.70.10-192.168.70.100
add name=iot-pool ranges=192.168.80.10-192.168.80.100
add name=guest-pool ranges=192.168.90.10-192.168.90.100
add name=mgmt-pool ranges=192.168.99.10-192.168.99.100
add name=restricted-main-pool ranges=192.168.11.10-192.168.11.100
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=main-pool interface=vlan10-main name=main-dhcp
add address-pool=phones-pool interface=vlan20-phones name=phones-dhcp
# No IP address on interface
add address-pool=wg-pool interface=vlan30-wireguard lease-time=12h name=wg-dhcp
add address-pool=dev-pool interface=vlan40-dev name=dev-dhcp
add address-pool=server-pool interface=vlan50-server name=servers-dhcp
add address-pool=nvr-pool interface=vlan60-nvr lease-time=12h name=nvr-dhcp
add address-pool=cameras-pool interface=vlan70-cameras lease-time=12h name=cameras-dhcp
add address-pool=iot-pool interface=vlan80-iot lease-time=12h name=iot-dhcp
add address-pool=guest-pool interface=vlan90-guest name=guest-dhcp
add address-pool=restricted-main-pool interface=vlan11-restricted-main lease-time=12h name=restricted-main-dhcp
add address-pool=mgmt-pool interface=vlan99-mgmt name=mgmt-dhcp
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment="defconf: trunk or main vlan access port" interface=ether1 pvid=10
add bridge=bridge comment="defconf: trunk port" interface=ether3
add bridge=bridge comment="defconf: trunk or dev vlan access port" interface=ether4 pvid=40
add bridge=bridge comment="defconf: trunk port" frame-types=admit-only-vlan-tagged interface=ether5
add bridge=bridge comment="defconf: trunk or nvr vlan access port" interface=ether6 pvid=60
add bridge=bridge comment="defconf: trunk port" frame-types=admit-only-vlan-tagged interface=ether7
add bridge=bridge comment="defconf: management access port" interface=ether8 pvid=99
add bridge=bridge comment="defconf: trunk port" frame-types=admit-only-vlan-tagged interface=sfp-sfpplus1
set discover-interface-list=MGMT
/interface bridge vlan
add bridge=bridge tagged=bridge,ether1,ether3,ether4,ether5,ether6,ether7,ether8,sfp-sfpplus1 vlan-ids=10
add bridge=bridge tagged=bridge,ether1,ether3,ether4,ether5,ether6,ether7,ether8,sfp-sfpplus1 vlan-ids=11
add bridge=bridge tagged=bridge,ether1,ether3,ether4,ether5,ether6,ether7,ether8,sfp-sfpplus1 vlan-ids=20
add bridge=bridge tagged=bridge,ether1,ether3,ether4,ether5,ether6,ether7,ether8,sfp-sfpplus1 vlan-ids=30
add bridge=bridge tagged=bridge,ether1,ether3,ether5,ether6,ether7,ether8,sfp-sfpplus1 untagged=ether4 vlan-ids=40
add bridge=bridge tagged=bridge,ether1,ether3,ether4,ether5,ether6,ether7,ether8,sfp-sfpplus1 vlan-ids=50
add bridge=bridge tagged=bridge,ether1,ether3,ether4,ether5,ether7,ether8,sfp-sfpplus1 untagged=ether6 vlan-ids=60
add bridge=bridge tagged=bridge,ether1,ether3,ether4,ether5,ether6,ether7,ether8,sfp-sfpplus1 vlan-ids=70
add bridge=bridge tagged=bridge,ether1,ether3,ether4,ether5,ether6,ether7,ether8,sfp-sfpplus1 vlan-ids=80
add bridge=bridge tagged=bridge,ether1,ether3,ether4,ether5,ether6,ether7,ether8,sfp-sfpplus1 vlan-ids=90
add bridge=bridge tagged=bridge,ether1,ether3,ether4,ether5,ether6,ether7,sfp-sfpplus1 untagged=ether8 vlan-ids=99
add interface=ether2 list=WAN
add interface=vlan10-main list=VLAN
add interface=vlan11-restricted-main list=VLAN
add interface=vlan20-phones list=VLAN
add interface=vlan30-wireguard list=VLAN
add interface=vlan40-dev list=VLAN
add interface=vlan50-server list=VLAN
add interface=vlan60-nvr list=VLAN
add interface=vlan70-cameras list=VLAN
add interface=vlan80-iot list=VLAN
add interface=vlan90-guest list=VLAN
add interface=vlan99-mgmt list=VLAN
add interface=ether1 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=sfp-sfpplus1 list=LAN
add interface=vlan10-main list=LAN
add interface=vlan11-restricted-main list=LAN
add interface=vlan20-phones list=LAN
add interface=vlan30-wireguard list=LAN
add interface=vlan40-dev list=LAN
add interface=vlan50-server list=LAN
add interface=vlan60-nvr list=LAN
add interface=vlan70-cameras list=LAN
add interface=vlan80-iot list=LAN
add interface=vlan90-guest list=LAN
add interface=vlan99-mgmt list=LAN
add interface=vlan10-main list=MGMT
add interface=vlan99-mgmt list=MGMT
add interface=vlan90-guest list=PREVENT_LAN
add interface=vlan70-cameras list=PREVENT_LAN
add interface=vlan80-iot list=PREVENT_LAN
add interface=vlan99-mgmt list=BASE
add interface=wireguard-main list=LAN
/interface wireguard peers
add allowed-address=192.168.30.101/32 interface=wireguard-main name=peer1 public-key="<valid key>"
add address=192.168.99.1/24 interface=vlan99-mgmt network=192.168.99.0
add address=192.168.10.1/24 interface=vlan10-main network=192.168.10.0
add address=192.168.20.1/24 interface=vlan20-phones network=192.168.20.0
add address=192.168.30.1/24 disabled=yes interface=vlan30-wireguard network=192.168.30.0
add address=192.168.40.1/24 interface=vlan40-dev network=192.168.40.0
add address=192.168.50.1/24 interface=vlan50-server network=192.168.50.0
add address=192.168.60.1/24 interface=vlan60-nvr network=192.168.60.0
add address=192.168.70.1/24 interface=vlan70-cameras network=192.168.70.0
add address=192.168.80.1/24 interface=vlan80-iot network=192.168.80.0
add address=192.168.90.1/24 interface=vlan90-guest network=192.168.90.0
add address=192.168.11.1/24 interface=vlan11-restricted-main network=192.168.11.0
add address=192.168.99.0/24 interface=vlan99-mgmt network=192.168.99.0
add address=19.168.30.1/24 interface=wireguard-main network=19.168.30.0
add address=192.168.30.1/24 comment="WG gateway" interface=bridge network=192.168.30.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf interface=ether2
add address=192.168.10.0/24 dns-server=192.168.50.100 gateway=192.168.10.1 next-server=192.168.50.100
add address=192.168.11.0/24 dns-server=192.168.88.1 gateway=192.168.11.1
add address=192.168.20.0/24 dns-server=192.168.50.100 gateway=192.168.20.1 next-server=192.168.50.100
add address=192.168.30.0/24 dns-server=1.1.1.1 gateway=192.168.30.1
add address=192.168.40.0/24 dns-server=192.168.88.1 gateway=192.168.40.1
add address=192.168.50.0/24 dns-server=192.168.50.100 gateway=192.168.50.1 next-server=192.168.50.100
add address=192.168.60.0/24 dns-server=192.168.88.1 gateway=192.168.60.1
add address=192.168.70.0/24 dns-server=1.1.1.1 gateway=192.168.70.1
add address=192.168.80.0/24 dns-server=1.1.1.1 gateway=192.168.80.1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.50.100 gateway=192.168.88.1 next-server=192.168.50.100
add address=192.168.90.0/24 dns-server=1.1.1.1 gateway=192.168.90.1
add address=192.168.99.0/24 dns-server=192.168.50.100 gateway=192.168.99.1 next-server=192.168.50.100
set allow-remote-requests=yes
add action=accept chain=input comment="Wireguard pass" dst-port=51820 in-interface=ether2 log=yes protocol=udp
add action=accept chain=input src-address=192.168.30.0/24
add action=accept chain=input comment="Allow DNS requests from WireGuard" dst-port=53 protocol=udp src-address=192.168.30.0/24
add action=accept chain=input comment="Allow DNS requests from WireGuard" dst-port=53 protocol=tcp src-address=192.168.30.0/24
add action=log chain=input comment="defconf: log all not coming from LAN" disabled=yes in-interface-list=!LAN log=yes log-prefix=NOT-LAN
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input comment="defconf: allow VLAN" in-interface-list=VLAN
add action=accept chain=input comment="defconf: allow Base_Vlan Full Access" in-interface-list=MGMT
add action=drop chain=input comment="defconf: drop"
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="defconf: VLAN Internet Access only" connection-state=new in-interface-list=VLAN out-interface-list=WAN
add action=accept chain=forward comment="defconf: allow management VLAN to access all VLAN" in-interface-list=MGMT out-interface-list=VLAN
add action=accept chain=forward comment="defconf: allow management VLAN to access all LAN" in-interface-list=MGMT out-interface-list=LAN
add action=accept chain=forward connection-state=established,related,new in-interface=wireguard-main log=yes out-interface-list=WAN src-address=\
192.168.30.0/24
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=drop chain=forward comment="defconf: drop"
add action=masquerade chain=srcnat in-interface=wireguard-main out-interface-list=WAN
add action=masquerade chain=srcnat comment="Default masquerade" out-interface-list=WAN
/ip service
set ftp disabled=yes
set telnet disabled=yes
set www disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Budapest
/system identity
set name="Router #1 [RB5009]"
/tool mac-server
set allowed-interface-list=MGMT
/tool mac-server mac-winbox
/tool romon
set enabled=yes
