Hi Everyone,
I am having trouble with WireGuard on my VRRP Mikrotik setup. If I setup the WireGuard client to use the VRRP IP address to connect I can see in the logs that the Mikrotik is responding on the physical IP so no handshake is happening. If I setup the WireGuard client to use the physical IP address to connect I can see in the logs that the Mikrotik is responding on the VRRP IP so again, no handshake is happening.
Any insight would be greatly appreciated.
