Wireguard behind CGNAT
Can Wireguard work behind CGNAT and also one side being dynamic.
This first setup would be Mikrotik to Mikrotik with one side being a static public IP (server side) with the other side a Mikrotik router with a LTE interface (USB dongle) using CGNAT?
The second setup would also be Mikrotik to Mikrotik again the server would have static public IP and the other side a Mikrotik router but a dynamic public IP.
I currently have both these configs working using SSTP VPN with the client connecting into the server but I’m considering moving over to Wireguard.
Yes, that should work. However you will have to use a script to update peer’s endpoint-address when the ip address changes.
You need at least one external point to connect to.
Dynamic or static does not matter. Can be solved with cloud ip.
I have setup like that with Hex at home and SXTLTE in France using Wireguard.
Thanks.
Make the unit with the public IP the server.
The office has Starlink with CG NAT.
The warehouse has a typical dynamic public IP address.
VPN to the warehouse… And it links you back to the office.
