I have issues with connecting a chr and a rb2011 to each other with wireguard. Nothing is happening. A packet caputure on both mikrotiks for port 51820 showed nothing.
I also setup road warriors via wireguard 1 on both mikrotiks, This works perfect.
wireguard1 interface is used for road warriors this is working perfectly
wireguard2 interface is used for connecting these 2 mikrotiks. This doesn’t work.
Quick question for the initial connection between the routers, which one is acting as the peer/client and which one is acting as the server?
One has to send an initial packet to establish the tunnel to the other.
After the tunnel is created it can be used to move traffic in either direction of course.
What exactly are you trying to do? With this config you should be able to access 10.251.251.x on the other side (if it’s not blocked by firewall). But if you’d want to connect LANs behind routers, you’d have to include them in peers’ allowed-address and add routes to them.
The idea is that both routers can access lan of both. I know I have to add tho’s subnets to the allowed addresses.
The point is that the tunnel between the two doesn’t establish. At both sites I did an packet capture on the wan interface for port 51820. No packets arive at both sides. It looks like both routers don’t sent the initial packet.
WG is a pretty easy interface to setup.
Once setup correctly, you should see packets flowing both sides rather quickly. That’s only way you’ll know it works before routing etc is handled.
Are you 200% sure that port 51820 is open to at least one of both routers ?
No other modem/device in between on either end which requires some port forwarding ?
Question:
what’s this double bracket doing there ?
endpoint-address={{WAN_IP}:51820
PS: you might want to remove some of the public info about your connection. It’s plain visible for everyone !
For now it doesn’t matter, it’s not working
It’s not only the route to the remote LAN subnet via the wireguard2 interface that is missing at both machines (or merely hasn’t been posted), it is also the subnet address of the remote LAN subnet that is missing on the allowed-address list on the /interface/wireguard/peer rows.
Other than that, I hazily remember the Wireguard not to attempt to establish the tunnel until it gets a payload packet to deliver. So start by pinging 10.251.251.1 from the 2011 while sniffing for traffic on port 51820.
