I’ve set on a ac2 (RBD52G-5HacD2HnD) for wireguard 2 peers - once I edit and save a peer the other peer is not working anymore. I’ve set the interface and peers like on this video on a pc https://www.youtube.com/watch?v=okihqaMni-w and also on an android.
About those peers from my router here are the details - on peers setup I test just activating or deactivating the check-box for responder (can be seen activated below for an inactive connection - and then the active one stop working, loading data on the mobile):
add admin-mac=48::D6 auto-mac=no comment=defconf name=bridge port-cost-mode=short
/interface wireless
set [ find default-name=wlan2 ] band=5ghz-n/ac channel-width=20/40/80mhz-Ceee disabled=no frequency=auto \
installation=indoor mode=ap-bridge name=5g ssid=MYROUTER-MT5
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors \
frequency=auto installation=indoor mode=ap-bridge name=24 ssid=MYROUTER-MT station-roaming=enabled wireless-protocol=802.11 \
wmm-support=enabled
/interface wireguard
add listen-port=27711 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wireguard peers
add allowed-address=192.168.55.11/24 client-address=192.168.55.11/24 client-endpoint=some-name.org client-listen-port=27711 \
comment=S24w interface=wireguard1 name=peer1 public-key="s55vcPXtKS..."
add allowed-address=192.168.55.23/24 client-address=192.168.55.23/24 client-endpoint=some-name.org client-listen-port=27711 \
interface=wireguard1 name=peer4 private-key="0I0ONRJ..." public-key=\"....2J92r1M="
add allowed-address=192.168.55.127/24 interface=wireguard1 name=peer202501 public-key=\"i....mg=" responder=yes
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=accept chain=input comment="Allow L2PT / IPSec / Wireguard VPN access" dst-port=500,1701,4500,27711 \
in-interface-list=WAN log=yes protocol=udp
add action=accept chain=input in-interface-list=WAN protocol=ipsec-esp
add action=accept chain=input in-interface-list=WAN protocol=ipsec-ah
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=\
new in-interface-list=WAN
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
/ip firewall mangle
add action=change-mss chain=forward comment="Fix MSS for VPN server" new-mss=1360 protocol=tcp src-address=192.168.21.0/24 \
tcp-flags=syn tcp-mss=!0-1360
add action=change-mss chain=forward comment="Fix MSS for VPN server" dst-address=192.168.21.0/24 new-mss=1360 protocol=tcp \
add action=masquerade chain=srcnat comment="Wirequard masquared" src-address=192.168.55.0/24
Would you please help with some thoughts? Thank you in advance!
