Wireguard, can't get access into LAN and haven't Internet
I’ve configured Wireguard (via cloud-host) in Mikrotik, can connect but can’t get access into LAN and haven’t Internet.
Where am i wrong?
I guess that there should be Firewall rule between VLAN with Internet access and wireguard1 (interface)?
Can anybody help me, please?
add admin-mac=00:2C:00:D4:00:00 arp=proxy-arp auto-mac=no comment=defconf \
    name=bridge vlan-filtering=yes
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    country=belgium disabled=no distance=indoors frequency=auto installation=\
    indoor mode=ap-bridge ssid="Net" wireless-protocol=802.11
/interface wireguard
add listen-port=443 mtu=1420 name=wireguard1
/interface vlan
add interface=ether1 name=vlan1 vlan-id=10
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan1 name=pppoe-out1 \
    use-peer-dns=yes user=NET
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
    supplicant-identity=MikroTik
add name=dhcp ranges=10.0.0.10-10.0.0.254
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/interface l2tp-server server
set default-profile=*1 use-ipsec=required
/interface wireguard peers
add allowed-address=9.0.0.3/32 interface=wireguard1 public-key=\
    "gL0X0+RPyXXXXXXXXXXXXXXXXcFxOFjaNVm0="
add address=10.0.0.1/24 comment=defconf interface=bridge network=10.0.0.0
add address=9.0.0.1/24 interface=wireguard1 network=9.0.0.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add address=10.0.0.0/24 comment=defconf dns-server=10.0.0.1 gateway=10.0.0.1 \
    netmask=24
set allow-remote-requests=yes
/ip dns static
add address=10.0.0.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
add action=accept chain=input comment="Allow WireGuard / SSL port" dst-port=\
    443 protocol=udp
add action=accept chain=forward comment="Allow WireGuard traffic" \
    in-interface=wireguard1 out-interface-list=WAN src-address=9.0.0.3
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat out-interface=pppoe-out1
add action=dst-nat chain=dstnat comment=VPN disabled=yes dst-port=443 \
    protocol=tcp to-ports=443
/ip upnp
set enabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
Tnx in advance!
Can you confirm you have two mikrotiks?
One in the cloud you connect to from the mikrotrik at home.
If so would need both configs…
Also its not clear so a network diagram to illustrate your plan would be great.
Hi Anav,
I have 1 home router, i need to get acces into may local-network from another place, from my work pc. Simple home VPN.
Client-server connection.
Got it so basically windows wireguard client from laptop/desktop at work, laptop from remote location (coffee shop), smartphone/pad from remote location.
Ensure you get windows wg client from wireguard home page and not microsoft itself.
To be clear you simply want to reach home LAN or did you want to use home internet?
I caution that if you don’t have permissions from WORK IT, to add a VPN and access internet bypassing WORK setup, you could be in violation of their rules, which I do not condone and for which you should be fired. In any case I will assume this is not the case. :slight_smile:
COMMENTS:
(1) add vlan1 as a WAN list member!
(2) you only have one wg client listed, surely you have more LOL. (iphone, ipad etc.)
(3) REMOVE IP dhcp client, as your wan interface setup is done through the pppoe interface settings!
(5) Firewall rules disorganized, put all input chain together and then forward chain, much easier to read/troubleshoot.
(6) Unless you use IPV6, get rid of all entries except what I have installed. If you use IPV6, then someone else should help LOL
(7) UPNP removed, should not be needed !! WHy do you have it.
(4) REMOVE SSL PORT 443 (input chain), has nothing to do with wireguard and if you have a server on the LAN as I see you have a destination NAT rule with 443, then nothing to do with input chain as well. Okay this needs more discussion. The question WHY did you use 443 for wireguard? The only reason to do this is if the Work IT system blocks all other ports? Is this the case??
Config predicated upon answers to 4..
Yes, so i mean!
Yes, i did it and configured. I can connect via WineGuard app but don’t have access into home LAN.
Exactly! :smiley: I work from guarded network where blocked all ports except 443 SSL port :slight_smile:
Do you have any advice? Must i remove all firewall rules and begin again?
Pay attention to interface list members and firewall/nat rules.
add arp=proxy-arp auto-mac=no comment=defconf \
/interface vlan
add interface=wireguard1 list=LAN
add interface=pppoe-out1  list=WAN
/ip cloud
    netmask=24
/ip dns static
{ Input Chain }
(default rules)
    invalid
(admin rules)
add action=accept chain=input comment="wireguard handshake" dst-port=443 protocol=udp
add action=accept chain=input comment="allow LAN access"  in-interface-list=LAN
add action=drop chain=input comment="Drop all else"  { put this rule in last of all the rules, at least ensuring the allow LAN rule above is in place first }
{ Forward Chain }
(default rules)
(admin rules)
add action=accept chain=forward comment="internet traffic" in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment="home access" in-interface=wireguard1 out-interface-list=LAN
add action=accept chain=forward comment="port forwarding" connection-nat-state=dstnat
add action=drop chain=forward comment="Drop all else"
add action=drop  chain=input comment="drop all"
add action=drop  chain=forward comment="drop all"
Hi Anav,
May be am i stupid? :confused:
I’ve removed all rules and did all again:
add admin-mac=DX:xx:xx:xx:xx:F3 arp=proxy-arp auto-mac=no comment=defconf \
/interface vlan
add interface=vlan1 list=WAN
    "gL0X0+xxxxxxxxxxxxxxxOFjaNVm0="
/ip cloud
/ip dhcp-client
    netmask=24
/ip dns static
    "defconf: accept established,related,untracked" connection-nat-state="" \
    invalid
add action=accept chain=input comment="wireguard handshake" dst-port=443 \
    protocol=udp
add action=accept chain=input comment="allow LAN access" in-interface-list=\
    LAN
add action=accept chain=forward comment="internet traffic" in-interface-list=\
add action=accept chain=forward comment="home access" in-interface=wireguard1 \
add action=accept chain=forward comment="port forwarding" \
/tool mac-server
/tool mac-server mac-winbox
This Wireguard config:
[Interface]
PrivateKey = gL0X0xxxxxxxxxxxxxxxxVm0=
Address = 9.0.0.3/32
DNS = 8.8.8.8
[Peer]
PublicKey = q6asXxxxxxxxxxxxxxxxvSQ=
AllowedIPs = 0.0.0.0/0
Endpoint = dexxxxxxxxxxaf.sn.mynetname.net:443
PersistentKeepalive = 10
Where am i wrong?..
Just need better attention to detail! :wink:
(1) Remove the line add interface=vlan1 list=WAN it wasnt on the config provided?
(2) You failed to remove this line or disable it.
/ip dhcp-client
(3) Security wise, you need this ASAP
After the rule below in italic, add the drop all rule as shown
add action=accept chain=input comment=“allow LAN access” in-interface-list=LAN
add action=drop chain=input comment=“Drop all Else”
**** OKAY I see the problem you added the input chain rule at the very bottom, move that up!!!
(4) THe drop invalid traffic rule in the forward chain should be ABOVE the allow internet traffic rule. Its the last default rule in the forward chain before the start of admin created rules for allowed traffic.
(5) YOU ARE MISSING the drop rule for the FORWARD CHAIN ( should be where you erroneously have the same input chain rule aka for drop )
(6) You can remove all those iPV6 addresses.
(7) Tool mac-server (by itself) should be set to NONE, its not a secure method to access the routers config.
Only the tool mac-server mac-winbox server should have the interface-list=LAN
See if progress can be made…
Hi Anav,
Tnx for your answer but there still same problem - no traffic between wireguard and LAN… I did all stap by stap.
Any idea?
add admin-mac=xx:xx:xx:xx:xx:xx arp=proxy-arp auto-mac=no comment=defconf \
/interface vlan
    "gL0X0xxxxxxxxxxxxxxxxaNVm0="
/ip cloud
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
    netmask=24
/ip dns static
    invalid
    protocol=udp
    LAN
/tool mac-server
Looks good.
Add another client for testing purposes (9.0.0.4/32) from your phone for example and test using an external cellular connection to your router.
See if the handshake rule on the input chain is reached as you can see the counter increase by one.
This will confirm that your public IP is reachable for example and the request at least reaches your router.
If not maybe the router is not reachable
If it does tick up, then suspect you may have mixed up keys for example.
From you phone over cellular can you ping your router using the dydndns URL???
Yes!! Thank you!
I can get access at router (ex., via browser 10.0.0.1) and to my NAS (too via browser). But i can’t to get access to shared SMB folders at my NAS (10.0.0.200).
Do you have some think?
Greetings!
PS. Anav, u r amazing! :smiley:
Okay so lets recap.
a. Wireguard handshake works, the input chain rule is tripped.
b. You can reach the router from the client and can config the router
c. YOu can reach the Bridge Subnet
d. you CANNOT reach a single device on the subnet the NAS SERVER.
There is nothing on the router preventing access.
The problem is a firewall on the NAS that is not accepting the 9.0.0.3 address at its door, check the NAS settings…
Hi Anav,
Tnx for your help! The probleem has been solved.
How can i buy beer for you? Send me your PayPal in pm, please.
Hi there, the payment is letting us all know what the issue was, so that we can better help others down the line, even if its an NAS error, PC error etc.
