Wireguard client allow for all bridge subnets
Dear board members, I am struggling with wireguard client firewall settings. I am able to connect to the wireguard interface with my client (192.168.90.100) and access the router via the web interface (192.168.88.1 - allowed via a firewall rule). There is another device on the network of the 88 (“bridge1”) subnet, e.g. 192.168.88.2 but even if I allow this device explicitly in the firewall, analogue to the allow-wireguard-router rule, it does not work. The same problem appears with the dhcp subnet and devices on this (e.g. 192.168.89.250) - I cannot ping or access them.
In my wiregurad client config, I set the Permitted-Networks to 192.168.0.0/16 (just to be sure) - and the subnet-jump from 192.168.90.x to 88.x seems to work. Or maybe this only works because the “wireguard” interface is in the .90.x subnet and thus accessible…?
What am I missing here? Maybe someone can help me since I am struggling for a while now. Thanks a lot in advance.
Find my config below
apr/15/2024 14:29:11 by RouterOS 7.8
software id = EZFV-DY09
model = CCR2004-1G-12S+2XS
serial number = > removed
add name=bridge1
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no name=wan-sfpplus1
speed=1Gbps
/interface wireguard
add listen-port=xxx name=wireguard-vpn
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.89.2-192.168.91.254
add address-pool=dhcp interface=bridge1 name=dhcp1
/port
set 0 name=serial0
set 1 name=serial1
add bridge=bridge1 interface=sfp-sfpplus2
add bridge=bridge1 interface=sfp-sfpplus3
add bridge=bridge1 interface=sfp-sfpplus4
add bridge=bridge1 interface=sfp-sfpplus5
add bridge=bridge1 interface=sfp-sfpplus6
add bridge=bridge1 interface=sfp-sfpplus7
add bridge=bridge1 interface=sfp-sfpplus8
add bridge=bridge1 interface=sfp-sfpplus9
add bridge=bridge1 interface=sfp-sfpplus10
add bridge=bridge1 interface=sfp-sfpplus11
add bridge=bridge1 interface=sfp-sfpplus12
add bridge=bridge1 interface=sfp28-1
add bridge=bridge1 interface=sfp28-2
add bridge=bridge1 disabled=yes interface=wan-sfpplus1
/interface detect-internet
set detect-interface-list=all internet-interface-list=WAN lan-interface-list=
LAN wan-interface-list=WAN
add interface=wan-sfpplus1 list=WAN
add interface=wireguard-vpn list=LAN
/interface wireguard peers
add allowed-address=192.168.90.100/32 comment=> removed > interface=
wireguard-vpn public-key=> removed
add address=> removed > comment=defconf disabled=yes interface=wan-sfpplus1
network=> removed
add address=192.168.88.1/22 interface=bridge1 network=192.168.88.0
add address=> removed > interface=wan-sfpplus1 network=> removed
add address=192.168.90.10/24 interface=wireguard-vpn network=192.168.90.0
/ip dhcp-client
add disabled=yes interface=wan-sfpplus1
/ip dhcp-server config
set store-leases-disk=2h5m
/ip dhcp-server lease
add address=192.168.88.2 client-id=> removed > mac-address=
removed > server=dhcp1
add address=192.168.89.250 client-id=> removed > mac-address=
add address=0.0.0.0/24 dns-server=0.0.0.0 gateway=0.0.0.0 netmask=24
add address=192.168.88.0/22 dns-server=192.168.88.1 gateway=192.168.88.1
netmask=22
set allow-remote-requests=yes servers=> removed
add action=accept chain=input comment=“WAN → Firewall Wireguard Access”
dst-port=xyz protocol=udp
add action=accept chain=input connection-state=established,related
add action=accept chain=input in-interface=bridge1
add action=accept chain=forward connection-state=established,related
add action=accept chain=forward in-interface=bridge1
add action=accept chain=input comment=“Allow Wireguard access” disabled=yes
in-interface=wireguard-vpn
add action=accept chain=input disabled=yes dst-address=192.168.88.1
add action=accept chain=input dst-address=192.168.88.0/22 in-interface=
wireguard-vpn
add action=drop chain=input
add action=accept chain=forward comment="Wireguard to LAN Access "
dst-address=192.168.88.0/22 in-interface=wireguard-vpn out-interface=
bridge1
add action=drop chain=forward
add action=log chain=input disabled=yes
/system clock
/system identity
set name= > removed
/system routerboard settings
set enter-setup-on=delete-key
(1) Why do you have your WAN address down twice ??? Oh I see the first one is disabled! Get rid of it, its garbage that creates confusion.
add address=removed comment=defconf disabled=yes interface=wan-sfpplus1
network=removed
add address=removed interface=wan-sfpplus1 network=removed
(2) why is your IP pool so big?? or is it a typo? Ah I see you have a /22 network, OKAY.
add name=dhcp ranges=192.168**.89**.2-192.168.91.254
(3) Dont keep garbage around remove the config line of wan on bridge ports!!
(4) I see you have one wireguard peer,
(5) Assuming you have fixed static public IP address (not private).
(6) Please fix your settings from ( never seen first line before self-invented?, regardless not required, do not put in net masks either )
netmask=22
TO
(7) Why are servers removed from /ip dns ( nothing hidden about 1.1.1.1, or 8.8.8.8 for example )
(8) Your firewall rules are woefully lacking for being an internet facing router, adjust to the following:
add action=accept chain=input connection-state=established,related,untracked
add action=drop chain=input connection-state=invalid
add action=accept chain=input comment=“wireguard handshake” dst-port=54896 protocol=udp
add action=accept chain=input comment=“accept LAN traffic only” in-interface-list=LAN
add action=drop chain=input comment=“Drop all else”
add action=fasttrack-connection chain=forward connection-state=established,related hw-offload=yes
add action=accept chain=forward connection-state=established,related,untracked
add action=accept chain=forward comment=“internet traffic” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“wg to LAN” in-interface=wireguard-vpn dst-address=192.168.88.0/22
add action=accept chain=foward comment=“port forwarding” disabled =yes connection-nat-state=dstnat { enable if required or remove }
add action=drop chain=forward comment=“Drop all else”
If your WANIP is a static public IP then you could do this instead for sourcenat rule.
add action=src-nat chain=srcnat out-interface=wan-sfpplus1 to-address=static-WAN-IP
Thanks for your advice on my configuration. I adjusted it and implemented your suggestions.
Still, I can’t access the other subnet(s). I.e. a connection between my Wireguard client and the Mikrotik is possible. But not to any other device on the net, e.g. another client or AP.
post your lastest config and perhaps a network diagram.
Sure, thanks for your time.
I thought the “input” and “forward” part of the firewall that you also proposed should allow the WG client to access or even just ping the AP or any client in the 192.168.88.x network but it does not work. Is there some kind of additional interface separation I am missing? Thanks in advance.
I did the quick network diagram with draw.io, tell me if you need more information or if I can help clarify.
apr/17/2024 08:08:08 by RouterOS 7.8
serial number = xxx
add name=bridge1
speed=1Gbps
add name=WAN
add name=LAN
/port
set 0 name=serial0
set 1 name=serial1
add allowed-address=192.168.90.100/32 comment=client1 interface=
wireguard-vpn public-key=“xyz”
add address=xyz interface=wan-sfpplus1 network=xyz
/ip dhcp-client
add address=192.168.88.2 client-id=xyz mac-address=
xyz server=dhcp1
add address=192.168.89.250 client-id=xyz mac-address=
xyz server=dhcp1
netmask=22
set allow-remote-requests=yes servers=82.144.41.8,82.145.9.8
add action=accept chain=input comment=“Wireguard Client Acccess” dst-port=
54896 protocol=udp
add action=accept chain=input comment=“accept LAN traffic only” in-interface=
bridge1
wireguard-vpn
add action=drop chain=input comment=“drop all else”
add action=accept chain=forward comment=“internet traffic” in-interface=
bridge1 out-interface=wan-sfpplus1
add action=accept chain=forward comment="Wireguard to LAN Netzwerkzugriff "
disabled=yes
/system clock
/system identity
set name=mikrotik
  1. Would recommend upgrade firmware to at least 7.12.2 later.
  2. Modify this rule. From
    add action=accept chain=input comment=“accept LAN traffic only” in-interface=bridge1
TO:
add action=accept chain=input comment=“accept LAN traffic only” in-interface**-list=LAN**
  1. REMOVE this rules its nonsensical. You are trying to control traffic through the router ( lan to lan, lan to wan, wan to lan) not in the proper forward chain, but in the input chain. which is traffic TO the router.
    wireguard-vpn
  2. Modify this rule:… From"
TO:
add action=accept chain=forward comment=“internet traffic” in-interface-list=LAN out-interface=wan-sfpplus1
Should be good to go.
Thanks for your comments! I adjusted the rules.
Still, I cannot ping or otherwise access a device in the “ether1” ethernet belonging to “bridge1” in the 192.168.88.x subnet from my Wireguard client in the 192.168.90.x subnet. I put a log in the firewall and can see that the ping attempts go into the appropriate forward rule of the firewall, the packets are not dropped there. So I assume it’s not a firewall problem?! I feel like I am missing something basic here.
Post your latest config with the changes please.
Sure, here we go
apr/22/2024 10:54:20 by RouterOS 7.8
serial number = xxx
add name=bridge1
speed=1Gbps
add name=WAN
add name=LAN
/port
set 0 name=serial0
set 1 name=serial1
add interface=ether1 list=LAN
add allowed-address=192.168.90.100/32 comment=xxx interface=
wireguard-vpn public-key=“xxx”
add address=xxx interface=wan-sfpplus1 network=xxx
/ip dhcp-client
add address=192.168.88.2 client-id=xxx mac-address=
xxx server=dhcp1
add address=192.168.89.250 client-id=xxx mac-address=
xxx server=dhcp1
netmask=22
54896 protocol=udp
add action=accept chain=input disabled=yes dst-address=192.168.88.0/22
add action=log chain=forward in-interface=wireguard-vpn log=yes
add action=accept chain=forward disabled=yes in-interface=wireguard-vpn
out-interface=bridge1
disabled=yes
/system clock
/system identity
set name=xxx
When people get cute they run into issues…
For example why do you have such a huge /22 network for the main subnet??
In any case, I think thats where you run into problems, overlap maybe??
(1) Try changing wireguard IP address to 192.168.80.1/24 interface=wireguard-vpn network=192.168.80.0
( shouldnt make a difference but grasping at straws here ). Of course, adjust client IP as well ( 192.168.80.100/32 )
(2) Minor, Remove ether1 from list=LAN, its covered by the fact that list=LAN includes bridge1, and ether1 is listed as a bridge port.
(3) Why is this rule here. what purpose do you think it serves?
(4) Why is this rule still in your config??
(5) Duplicate rule at end needs to be removed.
disabled=yes
(6)
Passing-by question, if a rule is “disabled=yes” isn’t its effect the same as it is not there (none)?
Hi Jaclaz, yes that is true…
Keep in mind that I read thoroughly all the configs, everytime I read a disabled rule that has no potential purpose I BARF,
Its a distraction and a waste of my time, to read a cluttered config full of garbage.
The cleaner and leaner the config, its easier for all to spot errors and do so efficiently. :slight_smile:
Therefore I care little that the last rule in the firewall rule, which was a duplicate, was also disabled.
I had to read the line, understand the line and then see that it was disabled… Once or twice fine, after a few 100 configs it gets old fast.
Its just good practice as well to keep a clean config, be it software coding or MT configs. Comments are good to let the reader know what you are doing as well.
Maybe this should be a request to Mikrotik, set an option in
/export
such as
hide-disabled=yes
or (possibly more in Mikrotik style)
show-not-enabled=no
I want to see the config, warts and all LOL and it may provide OP intentions thus I dont favour your approach.
I have no heartache with disabled rules that may have a purpose.
Case in point. ( planning on port forwarding later )
add action=accept chain=forward comment=“internet traffic” in-interface=list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“port forwarding” connection-nat-state=dstnat disabled=yes
So maybe a Mikrotik code parser for Scite/Scintilla or Notepad++ or similar that can find entries with disabled=yes and renders them striken or bold or anyway highlighted …
Nope, just a first post process that eliminates 99% of the problems I see on initial posts and one of the points would be cleaning up disabled rules that have no purpose.
Hey, sorry for the late reply.
Thanks a lot for your help so far. Indeed the overlapping subnets posed a problem. I am now able to ping the hosts in the bridge1 subnets / also the dhcp clients from the wireguard client.
Still, I cannot access e.g. the web interface of the AP (in the DHCP subnet xxx.xxx.88.2 , see my graphics). I can ping it without a problem. Web access to the mikrotik router (x.x.88.1) works fine. Web interface access with a client in the network on-site works fine. Any ideas?
Not without the latest config
Sure!
Ah and regarding question (3): This rule is supposed to allow access to the local subnet from wireguard. If I disable it, pings don’t work e.g.
apr/30/2024 12:59:07 by RouterOS 7.8
serial number = xxx
add name=bridge1
speed=1Gbps
add name=WAN
add name=LAN
/port
set 0 name=serial0
set 1 name=serial1
add allowed-address=192.168.80.100/32 comment=xxx interface=
add address=192.168.80.1/24 interface=wireguard-vpn network=192.168.80.0
xxx server=dhcp1
xxx server=dhcp1
netmask=22
54896 protocol=udp
add action=accept chain=forward comment="wireguard to LAN access "
/system clock
/system identity
set name=mikrotik
I just started another random web interface on one client in the dhcp subnet (x.x.89.250:3000) with a specific port and it works. SSH too. So I still don’t know why the AP web interface (x.x.88.2 http(s)) is not accessible but the major problem of not being able to access the subnets at all is solved I guess.
Remember: never have overlapping subnets. (:
Thanks so much anav!
