Hello Everyone,
I am trying to setup my first Mikrotik Wireguard Road Warrior VPN.
I have bridged the isp router and am doing the pppoe on the Mikrotik. I can connect with a Wireguard client and can ping the wireguard IP 192.168.0.1 and my Server IP 192.168.0.10.
I cannot however ping the server by its servername, only by it’s IP.
If anybody could help with this I would be very grateful.
Below is my config. Any other advice about what I should or should not have in their would also be appreciated.
# model = L009UiGS-2HaxD
# serial number = *****
add admin-mac=D4:01:C3:D0:A9:98 auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration.mode=ap .ssid=ssid disabled=\
no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=\
yes
/interface wireguard
add listen-port=21269 mtu=1420 name=wg1
/interface vlan
add interface=ether1 name=vlan167 vlan-id=167
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan167 keepalive-timeout=20 \
name=pppoe-1 user=****
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.0.101-192.168.0.199
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge comment=defconf interface=wifi1
add interface=pppoe-1 list=WAN
add interface=wg1 list=LAN
/interface wireguard peers
add allowed-address=192.168.77.2/32 interface=wg1 name=Lee public-key=\
add address=192.168.0.1/24 comment=defconf interface=bridge network=\
192.168.0.0
add address=192.168.77.1/24 interface=wg1 network=192.168.77.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip dhcp-client
add address=192.168.0.0/24 comment=defconf dns-server=\
192.168.0.1,192.168.0.10,69.63.64.12,8.8.8.8 gateway=192.168.0.1 netmask=\
24
set allow-remote-requests=yes servers=\
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan type=A
add address=192.168.0.10 name=SERVER type=A
established,related,untracked
invalid
add action=accept chain=input comment="Allow Wireguard" dst-port=21269 \
protocol=udp
add action=accept chain=forward comment="Allow Wireguard traffic on LAN" \
in-interface=wg1 out-interface=bridge
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=src-nat chain=srcnat dst-address=192.168.0.0/24 src-address=\
192.168.77.0/24 to-addresses=192.168.0.1
add action=masquerade chain=srcnat out-interface=pppoe-1 src-address=\
192.168.77.0/24
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Africa/Johannesburg
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
