Wireguard client can't access LAN
New to Mikrotik – although I am a fan already.
My setup:
Ubuntu client connecting to my WAN via a DynDNS IP with Wireguard.
WAN Firewall/Router (Zyxel Flex200h) forwards the WG port udp:51820 to the Mikrotik hEX (latest model) via 1:1 NAT.
hEX local IP: 192.168.1.60 (on ether port-2)
local LAN: 192.168.1.0/24 | router 192.168.1.1
IP for Wireguard 192.168.77.1/24 | network 192.168.77.0
Wireguard client IP: 192.168.77.2/32 | client DNS: 192.168.77.1 (is this correct?)
The client connects fine, it can ping the 192.168.77.0/24 range.
But nothing in the 192.168.1.0/24 range.
Using Torch on the Wireguard profile I can see the ping packages going to the hEX and then nothing.
Right now I am trying to set this up for testing, but ultimately the Wireguard clients should be available only on the hEX via one of the other ports:
#1 Client connects to hEX via WG
#2 Client can communicate with machines on let’s say port 5 of the hEX.
#3 Clients should not reach the main LAN (192.168.1.0/24)
my config is:
# 2025-05-31 14:12:16 by RouterOS 7.19.1
# software id = BM8J-9LKD
# model = E50UG
# serial number = XXXXX
add admin-mac=F4:1E:57:6A:D5:98 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment=alias1 name=1-WAN-PORT
/interface veth
add address=192.168.1.66/32 gateway=192.168.1.1 gateway6="" name=veth1
/interface wireguard
add comment="KIOSK WireGuard" listen-port=51820 mtu=1420 name=wireguard1
/disk
set usb1 media-interface=bridge media-sharing=yes smb-sharing=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp_pool1 ranges=192.168.77.11-192.168.77.254
/routing bgp template
set default disabled=no routing-table=main
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add comment=defconf interface=1-WAN-PORT list=WAN
add comment="WG LAN" interface=wireguard1 list=WAN
/interface ovpn-server server
add mac-address=FE:E9:A9:55:45:33 name=ovpn-server1
/interface wireguard peers
add allowed-address=0.0.0.0/0 client-address=192.168.77.2/32 client-dns=\
    192.168.77.1 interface=wireguard1 name=Kiosk-test-1 private-key=\
    "PRIV-KEY=" public-key=\
    "PUB-KEY/ZN+6Mz4="
    192.168.88.0
add address=192.168.77.1/24 comment="WG IP" interface=wireguard1 network=\
    192.168.77.0
/ip dhcp-client
add comment=defconf interface=bridge
# Interface not active
add interface=1-WAN-PORT
add address-pool=default-dhcp interface=bridge name=defconf
add address=192.168.77.0/24 dns-server=192.168.77.10 gateway=192.168.77.10
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
add action=accept chain=input comment="\F0\9F\9F\A1 KIOSK to KIOSK ADMIN" \
    dst-address=192.168.1.0/24 in-interface=wireguard1 log=yes src-address=\
    192.168.77.0/24
add action=accept chain=input comment="\F0\9F\9F\A1 KIOSK ADMIN to KIOSK" \
    dst-address=192.168.77.0/24 in-interface=wireguard1 log=yes src-address=\
    192.168.1.0/24
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat src-address=192.168.1.0/24
/ip ipsec profile
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/routing rule
add action=lookup disabled=no dst-address=::%ether2/128 src-address=\
    ::%wireguard1/128 table=main
/snmp
set contact="Mikrotik Contact" enabled=yes location=\
    "Mikrotik LOCATION 123 \C3\B6\C3\A4\C3\BC" trap-version=2
/system clock
/system identity
set name="MikroTik hEX"
/system logging
add disabled=yes topics=wireguard
/tool graphing interface
/tool graphing resource
add
/tool mac-server
/tool mac-server mac-winbox
  1. Why are you giving an IP pool to WIreguard, no such entity required, remove!!
  2. Why did you make the wireguard interface a member of the WAN interface list??
  3. The allowed addresses in peers, is to identify REMOTE device requireing access to the local router, or REMOTE subnets that local users need to access
    Therefore your peer settings are wrong and should only indicate 192.168.77.2
  4. WHY DO YOu have dhcp client set to the bridge, the WAN is coming NOT on the bridge but etherport1…
    So
    a. either use dhcp client interface=1-WAN-PORT
    OR
    b. use an IP address (static WAN) on interface 1-WAN-PORT
AKA should be:
/ip dhcp-client
  1. What are the purposes of these two rules…??
    add action=accept chain=input comment=“\F0\9F\9F\A1 KIOSK to KIOSK ADMIN”
    192.168.77.0/24
    add action=accept chain=input comment=“\F0\9F\9F\A1 KIOSK ADMIN to KIOSK”
    192.168.1.0/24
  2. Where is in the input chain rule for the handshake on the wireguard port ???
  3. What is the purpose of this sourcenat rule??
    add action=masquerade chain=srcnat src-address=192.168.1.0/24 ??
  4. If not using IPV6, should be disable and associated firewall address lists and firewall rules remvoed.
