wireguard client not shaking hands
I would like to connect my routeros device to a wireguard VPN server on Ubuntu linux. The server was setup this way:
https://techviewleo.com/install-wireguard-vpn-server-on-ubuntu/?expand_article=1
The linux side has a fixed ip, udp port 51820 opened on the firewall, and a peer is added:
#wg show
interface: wg0
  public key: Fgi*****************jHQ=
  private key: (hidden)
  listening port: 51820
peer: g5*******************EA=
  allowed ips: 0.0.0.0/0
  persistent keepalive: every 25 seconds
The client side (routeros HAP AX3) was setup this way:
/interface/wireguard
add name="wg-vpn" listen-port=12614
/interface/wireguard/peers
add interface=wg-vpn public-key="Fgi*****************jHQ=" endpoint-address=not_telling_com endpoint-port=51820 allowed-address=0.0.0.0/0 persistent-keepalive=25s
I also have this in the input chain:
 3    ;;; wireguard
      chain=input action=accept protocol=udp dst-port=12000-12999
Actually, I have mupltiple wireguard interfaces on this HAP AX3:
/interface wireguard
add listen-port=12614 mtu=1420 name=wg-cerebellum-loerolite
add listen-port=12714 mtu=1420 name=wg-laci-ekke
add listen-port=12414 mtu=1420 name=wg-laci-laptop
add listen-port=12514 mtu=1420 name=wg-laci-phone
add listen-port=12614 mtu=1420 name=wg-vpn
add listen-port=12314 mtu=1420 name=wg1
And many of them have peers that are working just fine. Here are some examples:
Flags: X - disabled; D - dynamic
 0    ;;;
      interface=wg1 public-key="8o**********QU=" endpoint-address=not_telling
      endpoint-port=12419 current-endpoint-address=not_telling current-endpoint-port=12419
      allowed-address=192.168.19.0/24,10.19.0.0/16,172.16.19.0/24 persistent-keepalive=25s rx=127.0KiB tx=323.9KiB
      last-handshake=7s
 1    ;;;
      interface=wg1 public-key="o5*********QY=" endpoint-address=not_telling
      endpoint-port=12305 current-endpoint-address=not_telling current-endpoint-port=12305
      allowed-address=192.168.5.0/24,172.16.5.0/24 persistent-keepalive=25s rx=3164.9MiB tx=845.3MiB last-handshake=1m22s
As you can see, the last-handshake is not that old, and they are working as expected. However, the working configurations are routeros devices on both ends. But this new one (called wg-vpn) that does not work is using Ubuntu linux on the other side.
First I thought that the problem must be on the linux side, since this is the first time I’m trying to use linux on the other side. But then I noticed two things. One is that tx=0 and rx=0 on the peer:
12    ;;; not_telling
      endpoint-port=51820 current-endpoint-address=not_telling current-endpoint-port=51820 allowed-address=0.0.0.0/0
      persistent-keepalive=25s rx=0 tx=0
The other thing is that it does not even try to do the handshake.
/system logging
add topics=wireguard,debug
/log/print follow
But it does not print out anything about it. Which is not what I would expect.
If I disable the wireguard interface on the remote (routeros) side of any other peers, then I see these messages popping up in the logs:
11:29:52 wireguard,debug wg-laci-laptop: s*********M=: Handshake for peer did not complete after 5 seconds, retrying (try 2)
11:29:52 wireguard,debug wg-cerebellum-loerolite: fc**********FQ=: Handshake for peer did not complete after 5 seconds, retrying (try 2)
11:29:52 wireguard,debug wg-laci-ekke: 6U******AQ=: Handshake for peer did not complete after 5 seconds, retrying (try 2)
But for this new peer, there are no logs at all. Seems like it is not trying to connect - even though the endpoint address was given, and persistent keepalive was set.
So there is no error message, and there is no log to examine.
I’m stuck, please help me.
All right, this was dumb. I accidentally gave the same listen port for two wireguard interfaces. The second one became invalid. All ip addresses and routes also became invalid. I could not find this out for some hours, because there was no error message and no log message anywhere. The only place where this was visible is the “I” status of the address under /ip/address, but I was not paying attention to that.
Problem solved. :slight_smile:
Not really, your ubuntu setup is wrong.
(1) The allowed IPs for the router depends.
Option1
allowed IPs=wireguardIP-assigned to router, subnets of router
Option2
Discussion:
Option 1 is the case where subnets from the router are going to visit subnets connected to the local Ubuntu or go out the Ubuntu internet and the subnet traffic is NOT sourcenatted to the wireguard IP of the Router on the way out. Note that in this case the ubuntu will have to have routes for the subnets so that return traffic is sent back to the subnets.
Option 2 is the case where the above is true BUT the Router sourcenats local MT traffic to the IP of the wireguard on the way out…
(2) On the server side, keep alive is not required, does nothing!
(3) Dont understand your inclusion of OTHER multiple wireguard interface on HAP?? Is it also acting as a server for other device but only a client to ubuntu??
