These log messages are coming from the Windows WireGuard client (from WireGuard.com), but the WireGuard tunnel which provokes these messages has one of my MikroTik routers as its Peer.
RouterOS 7.23.1
These messages/ messages like these appear occasionally in the WireGuard Windows client Log:
2026-06-05 23:38:17.325: [TUN] [MikroTik2WG-NOdefRoute] Packet has unallowed src IP (142.251.140.238) from peer 1 (83.41.122.160:56306)
2026-06-05 23:38:17.325: [TUN] [MikroTik2WG-NOdefRoute] Packet has unallowed src IP (13.83.125.1) from peer 1 (83.41.122.160:56306)
2026-06-05 23:38:17.325: [TUN] [MikroTik2WG-NOdefRoute] Packet has unallowed src IP (142.251.142.42) from peer 1 (83.41.122.160:56306)
2026-06-05 23:38:17.325: [TUN] [MikroTik2WG-NOdefRoute] Packet has unallowed src IP (50.85.242.216) from peer 1 (83.41.122.160:56306)
2026-06-05 23:38:17.325: [TUN] [MikroTik2WG-NOdefRoute] Packet has unallowed src IP (216.239.36.145) from peer 1 (83.41.122.160:56306)
2026-06-05 23:38:17.326: [TUN] [MikroTik2WG-NOdefRoute] Packet has unallowed src IP (34.107.243.93) from peer 1 (83.41.122.160:56306)
2026-06-05 23:38:17.326: [TUN] [MikroTik2WG-NOdefRoute] Packet has unallowed src IP (34.107.243.93) from peer 1 (83.41.122.160:56306)2026-06-05 22:44:40.193: [TUN] [MikroTik4WG-NOdefRoute] Packet has unallowed src IP (23.46.85.217) from peer 2 (83.40.90.106:56306)
2026-06-05 22:44:40.193: [TUN] [MikroTik4WG-NOdefRoute] Packet has unallowed src IP (23.45.153.96) from peer 2 (83.40.90.106:56306)
2026-06-05 22:44:40.193: [TUN] [MikroTik4WG-NOdefRoute] Packet has unallowed src IP (138.197.66.20) from peer 2 (83.40.90.106:56306)
2026-06-05 22:44:40.193: [TUN] [MikroTik4WG-NOdefRoute] Packet has unallowed src IP (34.107.221.82) from peer 2 (83.40.90.106:56306)2026-06-04 18:34:04.793: [TUN] [MikroTik3WG-NOdefRoute] Packet has unallowed src IP (216.239.36.145) from peer 1 (73.80.148.50:56306)
2026-06-04 18:34:04.798: [TUN] [MikroTik3WG-NOdefRoute] Packet has unallowed src IP (216.239.36.145) from peer 1 (73.80.148.50:56306)
2026-06-04 18:34:04.798: [TUN] [MikroTik3WG-NOdefRoute] Packet has unallowed src IP (138.197.66.20) from peer 1 (73.80.148.50:56306)
2026-06-04 18:34:04.798: [TUN] [MikroTik3WG-NOdefRoute] Packet has unallowed src IP (107.170.69.16) from peer 1 (73.80.148.50:56306)
2026-06-04 18:34:04.798: [TUN] [MikroTik3WG-NOdefRoute] Packet has unallowed src IP (52.123.159.129) from peer 1 (73.80.148.50:56306)
The MikroTik2WG-NOdefRoute, MikroTik3WG-NOdefRoute, MikroTik4WG-NOdefRoute are WireGuard Windows client configurations, peers configured on the Windows client for three of my different MikroTik routers (all running the same software and effectively the same configurations).
Here's a representative WireGuard 'server' configuration from my MikroTik2:
[admin@MikroTik2] /interface/wireguard> print detail
Flags: X - DISABLED; R - RUNNING
0 R name="wg1" mtu=1420 listen-port=12345 public-key="sCHAgUkqEf....................DjC900V219Aozk="
.. and the peer/ configuration for this Windows client:
[admin@MikroTik2] /interface/wireguard/peers> print detail where name="JayThinkT16-WG-MTik2"
Flags: X - DISABLED; D - DYNAMIC
1 interface=wg1 name="JayThinkT16-WG-MTik2" public-key="bCDnh..............................N4J2zFSo=" endpoint-address="" endpoint-port=0
current-endpoint-address=95.33.36.24 current-endpoint-port=58620 allowed-address=192.168.254.51/32 persistent-keepalive=30s client-endpoint=""
client-allowed-address=::/0 responder=yes rx=2621.4KiB tx=6.9MiB last-handshake=2d22h24m47s
(Ignore the old last-handshake; I just hadn't conneted lately when I took this print output).
And the MikroTik2WG-NOdefRoute configuration on the Windows client:
[Interface]
PrivateKey = {privateKey}
Address = 192.168.254.51/32
DNS = 192.168.254.3[Peer]
PublicKey = {publicKey}
PresharedKey = {presharedKey}
AllowedIPs = 192.168.254.0/24
Endpoint = http://mikrotik2-dyn.felines.org:12345
So, the Windows client only expects the /24 LAN on its MikroTik WireGuard peer MikroTik2 to come through this tunnel.
Routes on the MikroTik relating to WireGuard:
[admin@MikroTik2] /ip/route> print detail where gateway="wg1"
Flags: D - DYNAMIC; X - DISABLED, I - INACTIVE, A - ACTIVE;
c - CONNECT, s - STATIC, r - RIP, b - BGP, o - OSPF, i - IS-IS, d - DHCP, v - VPN, m - MODEM, y - BGP-MPLS-VPN; H - HW-OFFLOADED; + - ECMP
2 As ;;; WireGuard VPN route through BCN for Bremen/MikroTik3B temp June 2026
dst-address=192.168.251.0/24 routing-table=main gateway=wg1 immediate-gw=wg1 distance=1 scope=30 target-scope=103 As dst-address=192.168.254.51/32 routing-table=main pref-src=192.168.254.50 gateway=wg1 immediate-gw=wg1 distance=1 scope=30 target-scope=10
5 As dst-address=192.168.255.0/26 routing-table=main gateway=wg1 immediate-gw=wg1 distance=1 scope=30 target-scope=10
6 As dst-address=192.168.255.64/26 routing-table=main gateway=wg1 immediate-gw=wg1 distance=1 scope=30 target-scope=10
7 As dst-address=192.168.255.128/26 routing-table=main gateway=wg1 immediate-gw=wg1 distance=1 scope=30 target-scope=10
DAc dst-address=192.168.255.142/32 routing-table=main gateway=wg1 immediate-gw=wg1 distance=0 scope=10 target-scope=5
local-address=192.168.255.142%wg1
MikroTik2's overall situation is as a single IP client of some common ISP; nothing is routed to MikroTik2 from the Internet/ from the local LAN between the ISP router and the MikroTik2 except response packets to traffic generated outbound from behind MikroTik2. So, these 'unallowed source IP' packets that the Windows WireGuard client claims came through the peered-with-MikroTik2/3/4 routers should not have been sent towards the Windows WireGuard client by my MikroTiks.
Has anyone else seen seemingly spurious 'unallowed source IP' warnings on a WireGuard client (of any source) for packets coming through a WireGuard tunnel to a MikroTik router?
Do you see something in my configurations about which would actually mis-route packets from the MikroTik through this Windows WireGuard client's WireGuard tunnel ?
thanks,
