I’m trying quite hard to configure a client server roaming IP configuration between two MikroTik routers.
Site A has a public IP an I successfully connected a Windows machine and Android device to it. This client were behind natted networks with private IP’s.
But the goal is to ha site-to-site client0server between MikroTiks.
Server on site A has 10.10.100.200/24 for Wireguard and public IP
Client on site B has 10.10.100.100/24 for Wireguard and private natted IP.
I’m not able to configure the client to work. When I try to ping fro client to server the I can clearly seen traffic Tx and Rx on server site but on client it is not receivingActually it is reveivin on the WAN port but no passing it to Wireguard interface.
UDP port for wg in Firewall is open.
What should be the proper client configuration?
Client:
# INTERFACE PUBLIC-KEY ENDPOINT-ADDRE ENDPO ALLOWED-A
0 wireguard1 Server_public_key Server_public_IP Srv_port 0.0.0.0/0
Server:
0 wireguard1 Client_public_key no_endpoint no_port 10.10.100.100/24
Changing the allowed IP in client to servers IP does not change anything. What could be the problem?
