Hello everyone,
I found the process of setting up the wireguard client extremely complicated. So here I am after about 8 hours of struggling.
- My wireguard server is working and it took me 30 seconds to set up a windows client and verify that the connection was not the problem.
- My setup in the router OS seems to be sending data over the WG interface correctly: I see it in Torch. But nothing comes back. I have inbound and outbound firewall rules, but inbound rule does not show any traffic. Maybe Tx requests never left my router? But the handshake is successful and being maintained. I am so confused!
Could you please help me to solve this puzzle?
here is the setup:
add name=docker port-cost-mode=short
add name=local port-cost-mode=short
/interface veth
add address=88.0.0.2/24 gateway=88.0.0.1 gateway6="" name=pihole-veth
/interface wireguard
add listen-port=26015 mtu=1420 name=WG
/interface vlan
add interface=ether1 name=vlan-telekom vlan-id=7
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan-telekom max-mru=1492 \
max-mtu=1492 name=pppoe-telekom-fiber use-peer-dns=yes user=...
/container mounts
add dst=/etc/pihole name=etc_pihole src=/usb1/pihole-etc
add dst=/etc/dnsmasq.d name=dnsmasq_pihole src=/usb1/pihole-dns
/disk
set usb1 media-interface=none media-sharing=no slot=usb1
set usb2 media-interface=none media-sharing=no
add name=listBridge
add name=LAN
add name=WAN
add name=DNS
add name=VPN
add name=dhcp_pool0 ranges=192.168.0.100-192.168.0.254
add address-pool=dhcp_pool0 interface=local lease-time=10m name=dhcp1
/ip smb users
/routing table
add disabled=no fib name="VPN table"
/container
add envlist=envs_pihole interface=pihole-veth logging=yes mounts=\
etc_pihole,dnsmasq_pihole root-dir=usb1/pihole start-on-boot=yes
/container config
set registry-url=https://registry-1.docker.io tmpdir=usb1/containers
/container envs
add bridge=local interface=ether2 internal-path-cost=10 path-cost=10
add bridge=docker interface=pihole-veth internal-path-cost=10 path-cost=10
add bridge=local interface=ether3 internal-path-cost=10 path-cost=10
set udp-timeout=10s
set discover-interface-list=listBridge
add interface=local list=listBridge
add interface=ether1 list=WAN
add interface=pppoe-telekom-fiber list=WAN
add interface=vlan-telekom list=WAN
add interface=local list=LAN
add interface=docker list=LAN
add interface=docker list=DNS
add interface=WG list=VPN
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=... endpoint-port=... interface=WG name=firetv-peer persistent-keepalive=25s \
preshared-key=... public-key=...
add address=192.168.0.1/24 interface=local network=192.168.0.0
add address=88.0.0.1/24 interface=docker network=88.0.0.0
/ip cloud
set update-time=no
/ip dhcp-client
add disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.0.5 mac-address=... server=dhcp1
add address=192.168.0.0/24 dns-server=88.0.0.2 gateway=192.168.0.1
set allow-remote-requests=yes
/ip firewall address-list
add address=192.168.0.0/24 list=Local-LAN
add address=192.16.0.0/24 list=Guest-LAN
established,related,untracked
invalid
add action=accept chain=input comment="WireGuard Handshake" dst-port=26015 \
protocol=udp
add action=accept chain=input comment="Allow LAN" in-interface-list=LAN \
src-address-list=Local-LAN
add action=drop chain=input comment="Drop all"
connection-state=invalid
add action=accept chain=forward comment=DNS in-interface-list=LAN \
out-interface-list=DNS
add action=accept chain=forward comment="Internet traffic" in-interface-list=\
LAN out-interface-list=WAN
add action=accept chain=forward comment="LAN to VPN" in-interface-list=LAN \
out-interface-list=VPN
add action=accept chain=forward comment="VPN to LAN" in-interface-list=VPN \
out-interface-list=LAN
add action=drop chain=forward comment="Drop all"
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=WG routing-table=\
"VPN table" scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=88.0.0.0/24 gateway=docker \
routing-table="VPN table" scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=192.168.0.0/24 gateway=local \
/ip service
/ip smb shares
/ip ssh
set strong-crypto=yes
/ipv6 firewall address-list
add address=::224.0.0.0/100 comment="defconf: other" list=bad_ipv6
add address=::127.0.0.0/104 comment="defconf: other" list=bad_ipv6
add address=::/104 comment="defconf: other" list=bad_ipv6
add address=::255.0.0.0/104 comment="defconf: other" list=bad_ipv6
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/routing rule
add action=lookup-only-in-table disabled=no src-address=192.168.0.112/32 \
table="VPN table"
/system clock
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.nist.gov
/system routerboard settings
set auto-upgrade=yes
/tool bandwidth-server
set enabled=no
/tool mac-server
set allowed-interface-list=listBridge
/tool mac-server mac-winbox
