Wireguard Client - Traffic Routing Issue
Hi everyone, I really need your help. I’ve read through countless other guides on here and tried so many things. I am new to Mikrotik and losing it.
What I want to do:
  • Connect Mikrotik to my existing network for internet (I plugged in the WAN / Port 1, the Mikrotik is not direct to my router it’s direct to my home router)
  • Setup wireguard client (this works, I have confirmed)
  • Route all traffic on the router from any device on ethernet ports to the wireguard
As it stands:
  • Router with defaults has network no problem by just plugging in WAN
  • Connected laptop to mikrotik has access to local and internet, but does not route over Wireguard
I have tried adding the wireguard interface to the WAN list as per another post but it made no difference.
What am I missing here? I know I am doing something stupid but I have a hard time with routing and firewall, any help appreciated.
add admin-mac=B8:69:F4:B1:81:03 auto-mac=no comment=defconf name=bridge
/interface wireguard
add listen-port=51820 mtu=1384 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
/ipv6 settings
set disable-ipv6=yes
add interface=wireguard1 list=WAN
/interface wireguard peers
add allowed-address=0.0.0.0/0 client-allowed-address=0.0.0.0/0
endpoint-address=wg.starzone.io`` endpoint-port=1276 interface=wireguard1
name=peer1 persistent-keepalive=25s public-key=
"NsyFeiW4z67A5FEEX/FnFM5dCwwp+WwfbHwD7Q/h2go="
add address=192.168.88.1/24 comment=defconf interface=bridge network=
192.168.88.0
add address=10.2.153.196 interface=wireguard1 network=10.2.153.196
/ip dhcp-client
add comment=defconf interface=ether1 name=client1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add action=accept chain=input comment=
"defconf: accept established,related,untracked" connection-state=
add action=drop chain=input comment="defconf: drop invalid" connection-state=
invalid
in-interface=lo src-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN"
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy"
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy"
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack"
"defconf: accept established,related, untracked" connection-state=
add action=drop chain=forward comment="defconf: drop invalid"
connection-state=invalid
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat
in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade"
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute"
dst-port=33434-33534 protocol=udp
"defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500
protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=
!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6"
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1"
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=
ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=
ipsec-esp
!LAN
/system clock
set time-zone-name=America/New_York
/tool mac-server
/tool mac-server mac-winbox
What you need to additionally do is to:
  1. Add a routing table, with the name via-starzone for example:
    /routing table
    add fib name=via-starzone
  2. Add a default route in this routing table:
    add dst-address=0.0.0.0/0 gateway=wireguard1 routing-table=via-starzone
  3. Add the following routing rules to have all clients plugged to bridge to use the Wireguard interface for internet access:
    /routing rule
    add action=lookup min-prefix=0 table=main
    add action=lookup dst-address=0.0.0.0/0 interface=bridge table=via-starzone
That should do it!
If you also want to add some failsafe and have the LAN clients fallback to the default internet when Wireguard is not working, then replace step 2 above with these two routes instead:
  1. Add recursive routes, using 1.0.0.3 as canary:
    add dst-address=1.0.0.3/32 gateway=wireguard1 \
        routing-table=main scope=11 target-scope=10
    add dst-address=0.0.0.0/0 check-gateway=ping gateway=1.0.0.3@main \
        routing-table=via-starzone scope=30 target-scope=11
    See Simple recursive failover for bears of little brain for more details.
Thank you so much. Through reading and experimenting I had managed to get it working before your reply but my traffic was doing a weird thing where some websites seemed to get routed without the wireguard.
I can see based on your reply that my routing is possibly then issue. I'm going to restart the setup and configure it based on your suggestion.
Thank you
I forgot to mention that some MSS adjustments are needed otherwise you might experience MTU related connection issues. You should also add the following mangle rules to clamp the TCP MSS for connections going through wireguard.
/ip firewall mangle
add action=change-mss chain=forward comment="reduce MSS for WG" \
    new-mss=1344 out-interface=wireguard1 protocol=tcp tcp-flags=syn tcp-mss=1345-65535
    new-mss=1344 in-interface=wireguard1 protocol=tcp tcp-flags=syn tcp-mss=1345-65535
The values 1344 and 1345 are used based on the MTU value 1384 set on your WireGuard interface.
