Wireguard connection only works once: Keepalive problem?
I setup Wireguard on a Hex S but ran into an odd problem that I didn’t have on my AX2: Upon establishing a connection only a small amount of bytes would be forwarded through the tunnel. When I enabled client keepalive for a peer the problem was resolved but the connection would only work once, after a while I would run into the same problem. Opening the peer setup in WebFix and hitting apply made the Mikrotik reset the connection and then it works fine but this is not a practical solution. Anyone has an idea what could be wrong here? Config below:
# 2025-01-26 14:52:03 by RouterOS 7.17
# software id = xxx
# model = RB760iGS
# serial number = xxx
add admin-mac=74:4D:28:C8:A7:B6 auto-mac=no comment=defconf name=bridge \
    port-cost-mode=short
set [ find default-name=sfp1 ] disabled=yes
/interface wireguard
add listen-port=13231 mtu=1450 name=wireguard1
/interface vlan
add interface=ether1 name=vlan-internet vlan-id=300
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/ip smb users
/port
set 0 name=serial0
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
    path-cost=10
add bridge=bridge comment=defconf disabled=yes interface=sfp1 \
    internal-path-cost=10 path-cost=10
set udp-timeout=10s
add comment=defconf interface=vlan-internet list=WAN
add interface=wireguard1 list=LAN
/interface ovpn-server server
add mac-address=FE:5A:B8:55:54:D4 name=ovpn-server1
/interface wireguard peers
add allowed-address=10.255.255.3/24 client-keepalive=20s \
    endpoint-port=13231 interface=wireguard1 name=peer1 public-key=\
    "xxx"
add allowed-address=10.255.255.5/24 client-keepalive=20s \
    endpoint-port=13231 interface=wireguard1 name=peer2 public-key=\
    "xxx"
    192.168.88.0
add address=10.255.255.1/24 comment=wg interface=wireguard1 network=\
    10.255.255.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=odido interface=vlan-internet use-peer-dns=no use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.88.51 client-id=1:0:a:95:ba:8b:0 mac-address=\
    00:0A:95:BA:8B:00 server=defconf
    192.168.88.1
set allow-remote-requests=yes servers=62.58.48.20,37.143.84.228
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
add address=192.168.88.51 name=server type=A
add action=accept chain=input comment="allow WireGuard" dst-port=13231 \
    protocol=udp
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=dst-nat chain=dstnat dst-port=13231 in-interface=vlan-internet \
    protocol=udp to-ports=13231
/ip hotspot profile
/ip ipsec profile
/ip smb shares
set [ find default=yes ] directory=/flash/pub
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.pool.ntp.org
/tool mac-server
/tool mac-server mac-winbox
Only the client peers ON THEIR Devices, require keep alive settings.
You have some weird selections…
  1. Remove this dstnat rule, it is not required for standard wireguard usage.
  2. For peers, only really need the actual config parts, but I guess wireguard these days injects some client settings for some reason.,
    add allowed-address=10.255.255.3/24 interface=wireguard1 name=peer1 public-key=“xxx”
    add allowed-address=10.255.255.5/24 interface=wireguard1 name=peer2 public-key=“yyy”
  3. Purpose of these DNS addresses, what are they??
    set allow-remote-requests=yes servers=62.58.48.20,37.143.84.228 ??
  4. Reason for static DNS settings?
    /ip dns static
I removed this rule and indeed still works
  1. For peers, only really need the actual config parts, but I guess wireguard these days injects some client settings for some reason.,
Cleaned up, WG still works so that’s good
  1. Purpose of these DNS addresses, what are they??
This is for local DNS requests to be forwarded to the ISP DNS server
  1. Reason for static DNS settings?
    /ip dns static
This is for local servers, nothing fancy
Unfortunately the problem still persists, only the 1st session works and the 2nd session doesn’t anymore. Why could this be?
Try changing wireguard MTU to 1420 ( that is the normal default), I also dont see anything else at the moment
Okay I see one potential issue…
“xxx”
"xxx
TO:
add allowed-address=10.255.255.3/32 client-keepalive=20s
“xxx”
add allowed-address=10.255.255.5**/32** client-keepalive=20s
“xxx”
I made both changes as you recommended and it works now. I think the MTU could’ve been the culprit as it explains the intermittent issues and the internet connection is DSL. Thanks a lot!
