Wireguard DNS/Internet
I am struggling with my wireguard setup. Connecting to it is working as expected, however, I am not able to access the internet, resolve DNS names or access other VLANs. Could somebody please have a look at my configuration?
add ingress-filtering=no name=bridge port-cost-mode=short protocol-mode=none vlan-filtering=yes
/interface veth
add address=172.17.0.2/24 gateway=172.17.0.1 gateway6="" name=veth-dockers
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard_home
/interface vlan
add interface=bridge name=base-vlan vlan-id=10
add interface=bridge name=container-vlan vlan-id=60
add interface=bridge name=extern-vlan vlan-id=50
add interface=bridge name=iot-vlan vlan-id=20
add interface=ether1 name=isp-vlan vlan-id=32
add interface=bridge name=surveillance-vlan vlan-id=40
add interface=bridge name=voip-vlan vlan-id=30
/container mounts
add dst=/etc/pihole name=etc_pihole src=/ext-disk/etc
add dst=/etc/dnsmasq.d name=dnsmasq_pihole src=/ext-disk/etc-dnsmasq.d
add name=WAN
add name=VLAN
add name=BASE
add name=VLAN-LOCAL
add interface=base-vlan lease-time=10m name=base-dhcp
add interface=surveillance-vlan lease-time=10m name=surveillance-dhcp
add interface=extern-vlan lease-time=10m name=extern-dhcp
add name=base-pool ranges=10.0.10.10-10.0.10.254
add name=iot-pool ranges=10.0.20.10-10.0.20.254
add name=voip-pool ranges=10.0.30.10-10.0.30.254
add name=surveillance-pool ranges=10.0.40.10-10.0.40.254
add name=extern-pool ranges=10.0.50.10-10.0.50.254
add address-pool=iot-pool interface=iot-vlan lease-time=10m name=iot-dhcp
add address-pool=voip-pool interface=voip-vlan lease-time=10m name=voip-dhcp
/ip smb users
/user group
add name=home-assistant-group policy=reboot,read,write,policy,test,api,!local,!telnet,!ssh,!ftp,!winbox,!password,!web,!sniff,!sensitive,!romon,!rest-api
/container
add envlist=pihole_envs interface=veth-dockers mounts=etc_pihole,dnsmasq_pihole root-dir=ext-disk/pihole start-on-boot=yes
/container config
set registry-url=https://registry-1.docker.io tmpdir=ext-disk/pull
/container envs
add key=TZ name=pihole_envs value=Europe/Vienna
add key=WEBPASSWORD name=pihole_envs value=XXXX
add key=DNSMASQ_USER name=pihole_envs value=root
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus1 internal-path-cost=10 path-cost=10
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether4 internal-path-cost=10 path-cost=10 pvid=10
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether5 internal-path-cost=10 path-cost=10 pvid=20
add bridge=bridge interface=veth-dockers pvid=60
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether6 internal-path-cost=10 path-cost=10 pvid=50
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether7 internal-path-cost=10 path-cost=10 pvid=40
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether8 internal-path-cost=10 path-cost=10 pvid=30
set udp-timeout=10s
set discover-interface-list=BASE
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=bridge tagged=bridge,ether2,ether3,sfp-sfpplus1 untagged=ether4 vlan-ids=10
add bridge=bridge tagged=bridge,ether2,ether3,sfp-sfpplus1 untagged=ether5 vlan-ids=20
add bridge=bridge tagged=bridge,ether2,ether3,sfp-sfpplus1 untagged=ether8 vlan-ids=30
add bridge=bridge tagged=bridge,ether2,ether3,sfp-sfpplus1 untagged=ether7 vlan-ids=40
add bridge=bridge tagged=bridge,ether2,ether3,sfp-sfpplus1 untagged=ether7 vlan-ids=50
add bridge=bridge tagged=bridge,ether2,ether3 vlan-ids=60
add interface=isp-vlan list=WAN
add interface=base-vlan list=VLAN
add interface=iot-vlan list=VLAN
add interface=voip-vlan list=VLAN-LOCAL
add interface=surveillance-vlan list=VLAN-LOCAL
add interface=extern-vlan list=VLAN
add interface=ether4 list=BASE
add interface=base-vlan list=BASE
add interface=container-vlan list=VLAN
add interface=container-vlan list=BASE
add interface=wireguard_home list=BASE
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=10.0.100.2/32 comment="iPhone " interface=wireguard_home public-key="XXX"
add allowed-address=10.0.100.3/32 comment="iPhone " interface=wireguard_home private-key="XXX" public-key="XXX"
add address=10.0.10.1/24 interface=base-vlan network=10.0.10.0
add address=10.0.20.1/24 interface=iot-vlan network=10.0.20.0
add address=10.0.30.1/24 interface=voip-vlan network=10.0.30.0
add address=10.0.40.1/24 interface=surveillance-vlan network=10.0.40.0
add address=10.0.50.1/24 interface=extern-vlan network=10.0.50.0
add address=172.17.0.1/24 interface=container-vlan network=172.17.0.0
add address=10.0.100.1/24 interface=wireguard_home network=10.0.100.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add interface=isp-vlan use-peer-dns=no
/ip dhcp-server lease
add address=10.0.10.12 client-id="XX:XX:XX:XX:XX:XX" comment="WLAN-AP EG" mac-address="XX:XX:XX:XX:XX:XX" server=base-dhcp
add address=10.0.50.10 comment=Wallbox mac-address="XX:XX:XX:XX:XX:XX" server=extern-dhcp
add address=10.0.10.11 client-id="XX:XX:XX:XX:XX:XX" comment=NAS mac-address="XX:XX:XX:XX:XX:XX" server=base-dhcp
add address=10.0.10.10 client-id="XX:XX:XX:XX:XX:XX" comment=POE-Switch mac-address="XX:XX:XX:XX:XX:XX" server=base-dhcp
add address=10.0.10.14 client-id="XX:XX:XX:XX:XX:XX" comment=WLAN-AP-Outdoor mac-address="XX:XX:XX:XX:XX:XX" server=base-dhcp
add address=10.0.40.10 client-id="XX:XX:XX:XX:XX:XX" comment=IPCamCarport mac-address="XX:XX:XX:XX:XX:XX" server=surveillance-dhcp
add address=10.0.20.11 client-id="XX:XX:XX:XX:XX:XX" comment=Printer mac-address="XX:XX:XX:XX:XX:XX" server=iot-dhcp
add address=10.0.40.11 client-id="XX:XX:XX:XX:XX:XX" comment=IPCamDoor mac-address="XX:XX:XX:XX:XX:XX" server=surveillance-dhcp
add address=10.0.40.12 client-id="XX:XX:XX:XX:XX:XX" comment=IPCamCarden mac-address="XX:XX:XX:XX:XX:XX" server=surveillance-dhcp
add address=10.0.30.12 client-id="XX:XX:XX:XX:XX:XX" comment="IPPhone Gast" mac-address="XX:XX:XX:XX:XX:XX" server=voip-dhcp
add address=10.0.30.10 client-id="XX:XX:XX:XX:XX:XX" comment=PBX-Server mac-address="XX:XX:XX:XX:XX:XX" server=voip-dhcp
add address=10.0.30.11 client-id="XX:XX:XX:XX:XX:XX" comment="IPPhone B\FCro" mac-address="XX:XX:XX:XX:XX:XX" server=voip-dhcp
add address=10.0.30.13 client-id="XX:XX:XX:XX:XX:XX" comment="IPPhone Werkstatt" mac-address="XX:XX:XX:XX:XX:XX" server=voip-dhcp
add address=10.0.20.10 client-id="XX:XX:XX:XX:XX:XX" comment=X1 mac-address="XX:XX:XX:XX:XX:XX" server=iot-dhcp
add address=10.0.20.12 client-id="XX:XX:XX:XX:XX:XX" comment=Wechselrichter mac-address="XX:XX:XX:XX:XX:XX" server=iot-dhcp
add address=10.0.10.13 client-id="XX:XX:XX:XX:XX:XX" comment="WLAN-AP KG" mac-address="XX:XX:XX:XX:XX:XX" server=base-dhcp
add address=10.0.20.13 comment="W\E4rmepumpe" mac-address="XX:XX:XX:XX:XX:XX" server=iot-dhcp
add address=10.0.20.14 comment=Ofen mac-address="XX:XX:XX:XX:XX:XX" server=iot-dhcp
add address=10.0.10.15 client-id="XX:XX:XX:XX:XX:XX" comment="MAC mini - Celler" mac-address="XX:XX:XX:XX:XX:XX" server=base-dhcp
add address=10.0.20.15 client-id="XX:XX:XX:XX:XX:XX" comment="iPhone " mac-address="XX:XX:XX:XX:XX:XX" server=iot-dhcp
add address=10.0.20.16 client-id="XX:XX:XX:XX:XX:XX" comment="iPhone " mac-address="XX:XX:XX:XX:XX:XX" server=iot-dhcp
add address=10.0.10.254 client-id="XX:XX:XX:XX:XX:XX" comment="PC " mac-address="XX:XX:XX:XX:XX:XX" server=base-dhcp
add address=10.0.20.23 client-id="XX:XX:XX:XX:XX:XX" comment="iPad " mac-address="XX:XX:XX:XX:XX:XX" server=iot-dhcp
add address=10.0.10.253 comment="PC VM" mac-address="XX:XX:XX:XX:XX:XX" server=base-dhcp
add address=10.0.10.0/24 dns-server=10.0.10.1 gateway=10.0.10.1 ntp-server=10.0.10.11
add address=10.0.20.0/24 dns-server=10.0.20.1 gateway=10.0.20.1 ntp-server=10.0.10.11
add address=10.0.30.0/24 dns-server=10.0.30.1 gateway=10.0.30.1 ntp-server=10.0.10.11
add address=10.0.40.0/24 dns-server=10.0.40.1 gateway=10.0.40.1 ntp-server=10.0.10.11
add address=10.0.50.0/24 dns-server=10.0.50.1 gateway=10.0.50.1 ntp-server=10.0.10.11
set allow-remote-requests=yes servers=172.17.0.2
/ip dns static
add address=10.0.10.1 name=router.local
add address=10.0.10.11 name=nas.local
add address=10.0.10.10 name=switch.local
add address=10.0.10.12 name=wlan-ap-eg.local
add address=10.0.10.13 name=wlan-ap-kg.local
add address=10.0.10.14 name=wlan-ap-outdoor.local
add address=10.0.20.10 name=gira-x1.local
add address=10.0.20.11 name=printer.local
add address=10.0.20.12 name=inverter.local
add address=10.0.20.13 name=heat-pump.local
add address=10.0.30.10 name=voip.local
add address=10.0.30.11 name=void-phone-og.local
add address=10.0.30.12 name=void-phone-eg.local
add address=10.0.30.13 name=void-phone-kg.local
add address=10.0.40.10 name=camera-carport.local
add address=10.0.40.11 name=camera-door.local
add address=10.0.40.12 name=camera-garden.local
add address=10.0.50.10 name=wallbox.local
add address=172.17.0.2 name=pi-hole.local
add address=192.168.100.1 name=dishy.local
add action=accept chain=input comment="Allow Estab & Related" connection-state=established,related,untracked
add action=accept chain=input comment="Allow WireGuard handshake" dst-port=13231 protocol=udp
add action=accept chain=input comment="Allow WireGuard traffic" in-interface=wireguard_home src-address=10.0.100.0/24
add action=accept chain=input comment="Allow BASE Full Access" in-interface-list=BASE
add action=accept chain=input comment="Allow VLAN DNS Server Access" connection-state=new dst-port=53 in-interface-list=VLAN protocol=tcp
add action=accept chain=input connection-state=new dst-port=53 in-interface-list=VLAN protocol=udp
add action=accept chain=input comment="Allow VLANs NTP access" connection-nat-state="" connection-state=new dst-port=123 in-interface-list=VLAN-LOCAL protocol=udp
add action=accept chain=input connection-state=new dst-port=123 in-interface-list=VLAN protocol=udp
add action=drop chain=input comment=Drop
add action=fasttrack-connection chain=forward comment=Fasttrack connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="Allow Estab & Related & Untracked" connection-state=established,related,untracked
add action=accept chain=forward comment="Allow BASE access to all VLANs" connection-state="" in-interface-list=BASE out-interface-list=VLAN
add action=accept chain=forward comment="Allow BASE access to all VLANs" connection-state="" in-interface-list=BASE out-interface-list=VLAN-LOCAL
add action=accept chain=forward comment="Allow VLAN Internet Access" connection-state="" in-interface-list=VLAN out-interface-list=WAN
add action=accept chain=forward comment="Allow IOT SMB Access to NAS" connection-state="" dst-address=10.0.10.11 dst-port=445 in-interface=iot-vlan out-interface=base-vlan protocol=tcp
add action=accept chain=forward comment="Allow X1 Access to Surveillance Station" connection-state="" dst-address=10.0.10.11 dst-port=9900 in-interface=iot-vlan out-interface=base-vlan protocol=tcp
add action=accept chain=forward comment="Allow Mobile Access to InfluxDB" connection-state=new dst-address=10.0.10.11 dst-port=8086 in-interface=iot-vlan out-interface=base-vlan protocol=tcp src-port=""
add action=accept chain=forward comment="Allow Mobile Access to Surveillance Station" connection-state="" dst-address=10.0.10.11 dst-port=9901 in-interface=iot-vlan out-interface=base-vlan protocol=tcp
add action=accept chain=forward comment="Allow Mobile Access to File Station" connection-state="" dst-address=10.0.10.11 dst-port=7001 in-interface=iot-vlan out-interface=base-vlan protocol=tcp
add action=accept chain=forward comment="Allow Mobile Access to Home Assistant" connection-state="" dst-address=10.0.10.11 dst-port=8123 in-interface=iot-vlan out-interface=base-vlan protocol=tcp
add action=drop chain=forward comment=Drop
add action=drop chain=input comment="Drop Invalid" connection-state=invalid
add action=masquerade chain=srcnat comment="Default masquerade" out-interface-list=WAN
add action=masquerade chain=srcnat src-address=172.17.0.0/24
add action=dst-nat chain=dstnat dst-address=10.0.10.1 dst-port=888 protocol=tcp to-addresses=172.17.0.2 to-ports=80
/ip smb shares
set [ find default=yes ] directory=/pub
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=base-vlan type=internal
add interface=iot-vlan type=internal
/routing igmp-proxy interface
add alternative-subnets=10.0.20.0/24 interface=base-vlan upstream=yes
/system clock
set time-zone-name=Europe/Vienna
/system identity
set name=Router
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set broadcast=yes enabled=yes
/system ntp client servers
add address=0.at.pool.ntp.org
add address=1.at.pool.ntp.org
add address=2.at.pool.ntp.org
add address=3.at.pool.ntp.org
/tool mac-server
set allowed-interface-list=BASE
/tool mac-server mac-winbox
/tool sniffer
set file-limit=10000KiB file-name=wireguard_sniff filter-interface=wireguard_home filter-operator-between-entries=and filter-stream=yes streaming-server=10.0.10.254
Couple of things I notice:
Am missing the rule:
add action=accept chain=forward comment="Allow BASE Internet Access" connection-state="" in-interface-list=VLAN out-interface-list=BASE
Assuming BASE should have internet access (as the wireguard interface is part of the BASE address list).
Think these rules are unneccesary:
BASE is granted access, so there is no need to Allow wireguard specifically
Is this hit, as you have a dedicated NTP server on your NAS?
On the forward chain, the rule above this rule drops all:
Brrr…:
/ip upnp interfaces
set enabled=yes
/ip upnp interfaces
Love the firewall rules from a readability perspective! Be aware to remove any passwords :wink:
First of all, thank you for taking the time to take a look :smiley:
Awww, how could I have missed this? Thanks, that helped a lot, the internet access is now working.
Think these rules are unnecessary:
You are right, not needed, not hit. Thank you.
You are right, outdated, not hit. Thank you.
add action=drop chain=input comment=“Drop Invalid” connection-state=invalid
Not hit, makes sense, removed as well. Thank you.
> Brrr....:
> ```text
/ip upnp interfaces
set enabled=yes
/ip upnp interfaces
Don’t ask :laughing: I will try to get rid of it.
Love the firewall rules from a readability perspective! Be aware to remove any passwords > :wink:
Thank you! I am not too concerned about this one, but have to admit that I overlooked removing it. Thanks for the hint.
I have one final question if you do not mind. In case I want to be able to resolve static DNS names that I defined through a wireguard connection (eg. nas.local), what would be required?
I would expect it to be enough to set the DNS server client side to 10.0.100.1.
I have that already, but unfortunately, it does not work, and an attempt to resolve a DN times out. Using the IP works however.
Can you provide client config?
Is all Internet traffic routed through Wireguard?
All traffic is routed through wireguard (at least that was my intention setting allowed IPs to 0.0.0.0/0)
Ofc, peer config:
Addresses: 10.0.100.2/32
DNS Server: 10.0.100.1
Listen Port: auto
MTU: auto
Endpoint: XXX.subdomain.com
Allowed IPs 0.0.0.0/0
Exclude private IPs: off
Persistent keepalive: off
That should work (assuming the device can reach the MikroTiks DNS server).
And I think that is prohibited to VLAN as well…
I am not able to follow. If my understanding is correct, the wireguard_home interface is part of BASE and therefore should be covered by the accept input rule. VLAN also has two input rules for DNS access.
I see now…can you test the DNS server on the client?
By using nslookup (or any other Linux/iOS/Android equivalent)?
Does DNS resolve correct on any VLAN clients?
That’s strange.
DN lookup works (eg. tested printer.local) and the IP is correct, however, the ping of the domain name fails, and so does a request to the web interface in the browser. If I use the resolved IP (from NSLookup) instead everything works fine.
Yes, that works without problems.
