I have a Mikrotik CRS109 and a 1 Gbps internet connection. I tried to route all traffic over Wireguard(NordVPN) and it finally works, but the connection speed is much too slow.
Without wireguard it’s usually over 700 Mbps and with wireguard only around 50 Mbps. Is it normal or did i set something wrong?
set [ find default-name=ether1 ]
set [ find default-name=ether2 ] advertise="100M-half,100M-full,1000M-half,100\
0M-full,10000M-full,2500M-full,5000M-full" comment=Internet
set [ find default-name=ether3 ] advertise="100M-half,100M-full,1000M-half,100\
set [ find default-name=ether4 ] advertise="100M-half,100M-full,1000M-half,100\
set [ find default-name=ether5 ] advertise="100M-half,100M-full,1000M-half,100\
set [ find default-name=ether6 ] advertise="100M-half,100M-full,1000M-half,100\
set [ find default-name=ether7 ] advertise="100M-half,100M-full,1000M-half,100\
set [ find default-name=ether8 ] advertise=\
1000M-half,1000M-full,10000M-full,2500M-full,5000M-full \
disabled=yes full-duplex=no speed=100Mbps
/interface wireguard
add disabled=yes listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
/routing table
add disabled=no fib name=vpn
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
add comment=defconf interface=ether2 list=WAN
add interface=wireguard1 list=WAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=''.nordvpn.com \
endpoint-port=51820 interface=wireguard1 persistent-keepalive=25s \
public-key="----"
192.168.88.0
add address=10.5.0.2 disabled=yes interface=wireguard1 network=10.5.0.0
/ip firewall address-list
add address=192.168.88.0/24 list=local
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=accept chain=forward connection-mark=under_nordvpn disabled=yes
connection-state=invalid
add action=accept chain=forward out-interface=wireguard1 src-address=\
192.168.88.0/24
add action=masquerade chain=srcnat log=yes log-prefix=wg out-interface=\
wireguard1
add action=masquerade chain=srcnat disabled=yes out-interface=ether2
add check-gateway=ping disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=\
10.5.0.2 pref-src=0.0.0.0 routing-table=vpn scope=30 suppress-hw-offload=\
no target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wireguard1 pref-src=\
0.0.0.0 routing-table=vpn scope=30 suppress-hw-offload=no target-scope=10
/routing rule
add action=lookup disabled=yes dst-address=192.168.88.0/24 src-address=\
192.168.88.0/24 table=main
add action=lookup disabled=no src-address=192.168.88.0/24 table=vpn
/system clock
