I have ROS v7.10 with default configuration + following:
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard-inet
add address=10.2.0.2/32 interface=wireguard-inet network=10.2.0.1
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=37.199.111.111 endpoint-port=51820 interface=wireguard-inet persistent-keepalive=25s
add action=masquerade chain=srcnat out-interface=wireguard-inet src-address=192.168.88.0/24
add disabled=no distance=1 dst-address=0.0.0.0/1 gateway=10.2.0.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=128.0.0.0/1 gateway=10.2.0.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=no target-scope=10
set servers=10.2.0.1
/ip dhcp-client
set 0 use-peer-dns=no
add disabled=no dst-address=37.199.111.111/32 gateway=192.168.1.1 routing-table=main suppress-hw-offload=no
Is it possible use VPN just for specific websites, ex. google.com, if so, how I should adjust my config. Thank you
