Wireguard help - connected, but traffic won't route over WG; still works as usual
And by route I mean, even after the action=lookup-only-in-table, all my traffic still goes through the primary WAN instead of the wireguard.
To explain the structure a tiny bit (config below) I am using a hAp ax2 as a routed wireless bridge. I need to hide my geographic IP from my company. So the MT connects to the hotel etc wifi and then bridges the eth & local wifi to the clients. Everything on LAN should go through the WG, no need for any specialty config at the moment.
Got this part working in about 10 mins. Actually I use the 2.4G radio for the provider wifi as client, and then the 5G radio for my devices. Figure no point splitting both connections in half using virtual APs. Anyway, that part is working.
I have two VPN providers and as yóu can see in the config I’ve had a few stabs at various setups. Just ignore the IPSEC attempts for now, though eventually I do want to have a scenario where I can disable certain IFs and/or policies, and enable others, to have the MT switch over from WG to IKEv2, or from one VPN provider to another, depending on my needs at the time. But that’s for later.
Anyway I have the WG2 if running, it tells me, and I believe I’ve configured the correct routes, and route table, and masquerade route, and as mentioned the action=lookup-in-table-only set. Which should block all traffic if it’s not routed to WG from what I’ve been led to believe. So the traffic is not going down the WG path, but the internet still works just fine:
[ 5ghz CLient] ---- Wifi2 ---- { MT ] ---- Wifi1 ----- [2.4 ghz Hotel wifi]
The WG if should be used for the traffic from my LAN. But it doesn’t. I also see when looking at Routing/Tables, that both WG tables are marked ‘not used’, even though they are both definitely selected in the rules & routes.
Now just checking back, I see that, for the first time, the Nordvpn WG if appears to have connected - but the Purevpn if now reports “Invalid” on the addresses page (I’m using Webfig primarily). [Side note, is it normal that I can’t paste into the Terminal in Webfig? It’s horribly inconvenient like that.. ]
There are a couple of other bugs I’m seeing, like the thread I raised a couple ours ago where it seems either the time service is buggy or the device is powering off on occasion.. not helpful :confused: But the WG config is the first priority, I guess..
Appreciate any help anyone can give, and thanks in advance.. :bulb:
Oh also is the NordVPN cert chain issue from ROS 7.5 & up fixed yet? My 7.7 has this issue at present. :confused:
# jun/07/2023 04:16:42 by RouterOS 7.7
# software id = 3KBA-BDED
# model = C52iG-5HaxD2HaxD
# serial number = [...]
add name=bridge-Mgmt
add admin-mac=[...] auto-mac=no comment=defconf name=bridge-lan
add name=bridge-wan
/interface wifiwave2
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac configuration.mode=ap .ssid=mikko disabled=no security.authentication-types=wpa2-psk,wpa3-psk .encryption=ccmp,gcmp,ccmp-256,gcmp-256
/interface wireguard
add listen-port=13231 mtu=1420 name=wg1-nordvpn
add listen-port=13231 mtu=1420 name=wg2-purevpn
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment="Device Mgmt only. " name=Mgmt
/interface wifiwave2 security
add authentication-types=wpa-psk,wpa2-psk,wpa3-psk comment="1st setup 230605" encryption=tkip,ccmp,gcmp,ccmp-256,gcmp-256 name=SCInn
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac configuration.mode=station .ssid="SC INN HOTELS" disabled=no security=SCInn security.authentication-types=wpa2-psk,wpa3-psk
/ip ipsec mode-config
add name=NordVPN.base responder=no
add name=Nord-01-modeconfig responder=no
/ip ipsec peer
add address=de-ipsec.ptoserver.com comment="PureVPN - Preferred IPSEC Server DE" disabled=yes name=PureVPN-IpSec-DE
/ip ipsec policy group
add name=PureVPN.base
add name=Nord-01-policygroup
/ip ipsec profile
add enc-algorithm=aes-256 hash-algorithm=sha384 name=Nord1.base-aes256.sha384
add enc-algorithm=aes-256,aes-128,3des name=PureVPN.base-3des.sha1
add name=Nordvpn-ipsec01
add name=Nord-01-profile
/ip ipsec peer
add address=nl1.pointtoserver.com comment="PureVPN LTTP/IPSEC NL preferred server\
    \n" disabled=yes exchange-mode=ike2 name=PureVPN-LttP/Ipsec-NL profile=PureVPN.base-3des.sha1
add address=nl125.nordvpn.com exchange-mode=ike2 name=Nord-NL-peer01 profile=Nord-01-profile
add address=nl2-auto-ipsec.ptoserver.com comment="PureVPN - Preferred IPSEC Server NL" disabled=yes name=PureVPN-IpSec-NL profile=PureVPN.base-3des.sha1
add address=nl983.nordvpn.com comment="NordVPN primary IPSEC - NL" disabled=yes exchange-mode=ike2 name=Nord01-NL profile=Nord1.base-aes256.sha384
add address=sx051756-ikev.ptoserver.com comment="PureVPN IPSEC generated server address" disabled=yes exchange-mode=ike2 name=PureVPN-generatedNL profile=PureVPN.base-3des.sha1
add address=us2-auto-ipsec.ptoserver.com comment="PureVPN - Preferred IPSEC Server US" disabled=yes name=PureVPN-IpSec-US profile=PureVPN.base-3des.sha1
/ip ipsec proposal
add auth-algorithms=sha512,sha256,sha1 name=Nord1.base-shax.aesx pfs-group=none
add auth-algorithms=sha256 name=PureVPN.Prop-sha256.aesx pfs-group=none
add name=Nord-01-proposal pfs-group=none
add name=dhcppool-lan113 ranges=192.168.113.100-192.168.113.239
add name=dhcppool-mgmt99 ranges=192.168.99.100-192.168.99.113
add name=dhcp_pool113v2 ranges=192.168.113.100-192.168.113.239
add address-pool=dhcppool-mgmt99 interface=bridge-Mgmt name=dhcp-mgmt99
add add-arp=yes address-pool=dhcp_pool113v2 interface=bridge-lan lease-time=2h name=dhcp-lan113
/routing table
add disabled=yes fib name=routeWG-Pure
add disabled=no fib name=routeWG-Nord
add bridge=bridge-lan comment=defconf interface=ether2
add bridge=bridge-lan comment=defconf interface=ether3
add bridge=bridge-lan comment=defconf interface=ether4
add bridge=bridge-Mgmt comment=defconf interface=ether5
add bridge=bridge-wan interface=ether1
add bridge=bridge-lan comment=5g/AX-Mikko interface=wifi1
set discover-interface-list=WAN lldp-med-net-policy-vlan=1
add comment=defconf interface=bridge-lan list=LAN
add interface=wifi2 list=WAN
add comment="Dedicated mgmt port to prevent lockouts. " interface=bridge-Mgmt list=Mgmt
add interface=wg1-nordvpn list=LAN
add interface=bridge-wan list=WAN
add interface=wg2-purevpn list=LAN
/interface wireguard peers
add allowed-address=0.0.0.0/0 comment="Nordlynx Server 826 NordVPN Wireguard" disabled=yes endpoint-address=nl826.nordvpn.com endpoint-port=51820 interface=wg1-nordvpn public-key="CKMAE9LARlt2eZHgGnNaSUYiKllKJN7f3hed/bWm5E8=F30"
add allowed-address=0.0.0.0/0 comment="Nordlynx Server 897 NordVPN Wireguard" disabled=yes endpoint-address=159.48.55.216 endpoint-port=51820 interface=wg1-nordvpn public-key="CKMAE9LARlt2eZHgGnNaSUYiKllKJN7f3hed/bWm5E8="
add allowed-address=0.0.0.0/0 comment="NordLynx server NL-977 NordVPN Wireguard" disabled=yes endpoint-address=nl977.nordvpn.com endpoint-port=51820 interface=wg1-nordvpn public-key="K53l2wOIhU3262sX5N/5kAvCvt4r55lNui30EbvaDlE="
add allowed-address=0.0.0.0/0 comment="NordLynx Server UK-1818 NordVPN Wireguard" disabled=yes endpoint-address=uk1818.nordvpn.com endpoint-port=51820 interface=wg1-nordvpn public-key="K53l2wOIHU3262sX5N/5kAvCvt4r55lNui30EbvaDlE="
add allowed-address=0.0.0.0/0 comment="PureVPN WG NL-sx050159" endpoint-address=sx050159-wg.pointtoserver.com endpoint-port=51820 interface=wg2-purevpn persistent-keepalive=21s public-key="FSnxjK+/pP7ZJ3hbzGS1WDWtXruz/qTFqPIRIUMW7lo="
add allowed-address=0.0.0.0/0 comment="nord-FR\?" endpoint-address=37.19.217.30 endpoint-port=51280 interface=wg1-nordvpn persistent-keepalive=25s public-key="FT46M53w4dhBep/2VScW1j/EoZbpBgzvk71FlLZLDBM="
add address=192.168.113.1/24 comment=defconf interface=bridge-lan network=192.168.113.0
add address=192.168.99.99/27 comment="Spare IF to prevent lockout" interface=bridge-Mgmt network=192.168.99.96
add address=172.25.35.181 comment="PureVPN-provided WG Interface IP" interface=wg2-purevpn network=172.25.35.181
add address=10.5.0.2 interface=wg1-nordvpn network=10.5.0.2
/ip dhcp-client
# DHCP client can not run on slave or passthrough interface!
add disabled=yes interface=wifi1
add default-route-distance=2 interface=wifi2
add address=192.168.13.0/24 comment=HomeLan dns-server=193.168.13.1 gateway=192.168.13.1
add address=192.168.99.0/24
add address=192.168.113.0/24 dns-server=192.168.113.1 gateway=192.168.113.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.113.1 comment=defconf name=router.lan
/ip firewall address-list
add address=192.168.113.0/24 list=vpnrouted
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input comment="Allow mgmt traffic & log. " in-interface-list=Mgmt log=yes protocol=tcp
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="masq WG-pureVPN" out-interface=wg2-purevpn
/ip ipsec identity
add auth-method=pre-shared-key-xauth comment="PureVPN-1698\
    \n[....]\
    \n[...]" peer=PureVPN-IpSec-NL username=yjtyjtyjtyjytjytj
add auth-method=eap certificate=root.der_0 eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=Nord-01-modeconfig peer=Nord-NL-peer01 policy-template-group=Nord-01-policygroup username=[...]
/ip ipsec policy
set 0 disabled=yes
add disabled=yes peer=PureVPN-IpSec-NL proposal=PureVPN.Prop-sha256.aesx
add disabled=yes dst-address=0.0.0.0/0 group=Nord-01-policygroup proposal=Nord-01-proposal src-address=0.0.0.0/0 template=yes
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=172.25.35.181 pref-src="" routing-table=routeWG-Pure suppress-hw-offload=no
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=wg2-purevpn pref-src="" routing-table=routeWG-Pure suppress-hw-offload=no
/ip service
set www address=192.168.0.0/16
set api address=192.168.0.0/16
set winbox address=192.168.0.0/16
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/routing rule
add action=lookup-only-in-table disabled=yes interface=wg2-purevpn routing-mark=routeWG-Pure src-address=192.168.113.0/24 table=routeWG-Pure
add action=lookup-only-in-table disabled=no interface=wg1-nordvpn routing-mark=routeWG-Nord src-address=192.168.113.0/24 table=routeWG-Nord
/system clock
set time-zone-name=Europe/Istanbul
/tool mac-server
/tool mac-server mac-winbox
Soooo is it because I’m doing something really dumb, that no-one wants to answer?
Its the weekend people have a life, would lov to look but may have a chance tonight.
PureVPN Wireguard works fine here in RouterOS 7.0
I asume you already Wireguard manual configuration config downloaded from purevpn member area.
  1. create Wireguard interface and peers
  2. create ip address (IP in config files) to WG Interfaces
  3. Create route table FIB
  4. Create route Rules. Scr. Address=“yourDeviceIP” action=“lookup only in table” , table=“yourRouteTable”
  5. Create IP Route. Dst address 0.0.0.0/0 , Gateway=“YourWGInterface”, Routing Table=“yourRouteTable”
I need to hide my geographic IP from my company. <— Not interested in helping!
What do you care what I want to use it for? Ok changed my mind, I want to use it to have my home VPN see a local IP. Good now?
Like I said.. the if is up. I created the route, and set ‘lookup only in table’. This on its own should block all traffic if Watchguard-if is not used. But WG tunnel is not used, and I can still access the net.
https://forum.mikrotik.com/viewtopic.php?t=182340 only thing I will offer.
Yes I followed that.. that’s how I got where I am at the moment.
Unsure what your problem is, are you part of the illuminati pulling world labour strings and can’t fathom the idea of an employee subverting corporate dictatorship? Just seems a strange personal principle to take.
hello @op,
are you sure about this wg interface setup?
Not really, if you cannot ask your company IT to setup the equipment as you need it and you are circumventing the IT rules, then its called illegal in most places.
Criminal, depending upon the sensitivity of the information being handled.
If you are IT, and you need access to the internet to get work done for work thats a different matter, however it would seem you want access to internet for personal reasons, which is fine in most corporations within some limits as set by filters, but in this case you want to hide IP address which makes things murkier… Sounds less legit the more I t hink about it.\
Not to worry there are many here lacking ethics or morals… :slight_smile:
I’m not certain-certain but the IF is up, according to the MT. It’s the information I could find for those providers.
That’s quite ridiculous. There is nothing legal about a company’s requirements /IT rules.
Also not sure how you got any indication it was for personal purposes. I have other devices for that. So that’s another huge leap of imagination.
There are a great many reasons to hide an IP and as you are clearly an experienced networking guy you can probably think of even more than I can.
@ op,
your router needs to listen on different port - for the wg tunnels to be usable. ie. 13231 for nordvpn and 13232 for purevpn.
