Wireguard help - Everything works except one IP
I’ve only had a Miktorik router for a short time and I’m not that experienced with network things.
I have a NAS running Nextcloud in a Docker container (192.168.0.2). I also have a static IP from my ISP. To make the Nextcloud reachable from the outside, I forwarded port 80 and 443 to 192.168.0.2. So that the Nextcloud is also accessible in the LAN via the domain, I have set up a hairpin NAT. This all works so far. Except for the described I have not changed the rules by hand.
Now I have set up a Wireguard server (https://www.youtube.com/watch?v=vn9ky7p5ESM). With my Android phone I can establish the connection and can also connect to all devices in my network, except to the NAS (192.168.0.2). Probably there is a conflict with the port forwarding or the hairpin NAT. Can anyone help me?
Router config:
# jun/08/2023 06:39:23 by RouterOS 7.9.2
# software id = W9AR-VJMJ
# model = RB750Gr3
# serial number = HDD08XXYYYXXX
add admin-mac=18:FD:74:F4:93:DA auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1-wan
set [ find default-name=ether2 ] name=ether2-lan
set [ find default-name=ether3 ] name=ether3-lan
set [ find default-name=ether4 ] name=ether4-lan
set [ find default-name=ether5 ] name=ether5-lan
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add name=dhcp ranges=192.168.0.50-192.168.0.240
add address-pool=dhcp interface=bridge lease-time=10m name=defconf
/port
set 0 name=serial0
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2-lan
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3-lan
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4-lan
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5-lan
/ipv6 settings
/interface l2tp-server server
set authentication=mschap1,mschap2 use-ipsec=required
add comment=defconf interface=ether1-wan list=WAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add allowed-address=192.168.100.2/32 comment=Android interface=wireguard1 \
    public-key="lEE4mpqhu37-hhhhhhhhhhhhhh"
add address=192.168.0.1/24 comment=defconf interface=bridge network=\
    192.168.0.0
add address=192.168.100.1/24 interface=wireguard1 network=192.168.100.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.0.21 comment=OpenDTU mac-address=B4:E6:2D:96:2B:75 \
    server=defconf
add address=192.168.0.25 comment="Shelly 1PM Luftentfeuchter" mac-address=\
    A8:03:2A:B7:7E:B0 server=defconf
add address=192.168.0.22 comment="Shelly 3EM" mac-address=24:4C:AB:41:A8:24 \
    server=defconf
add address=192.168.0.23 comment=Gasmeter mac-address=94:B5:55:FC:47:F0 \
    server=defconf
add address=192.168.0.24 comment=Watermeter mac-address=94:B5:55:FC:59:0C \
    server=defconf
add address=192.168.0.26 comment="Shelly 1 PM Heizstab" mac-address=\
    3C:61:05:79:D4:74 server=defconf
add address=192.168.0.20 comment=Roborock mac-address=50:EC:50:0E:1B:F3 \
    server=defconf
add address=192.168.0.0/24 comment=defconf dns-server=192.168.0.2 gateway=\
    192.168.0.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.0.1 comment=defconf name=router.lan
add action=accept chain=input src-address=192.168.100.0/24
add action=accept chain=input dst-port=13231 protocol=udp
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat comment="Hairpin NAT" dst-address=\
    192.168.0.2 out-interface=bridge protocol=tcp src-address=192.168.0.0/24
add action=dst-nat chain=dstnat comment="Nextcloud http" dst-address=\
    xxx.xxx.x51.94 dst-port=80 protocol=tcp to-addresses=192.168.0.2 to-ports=\
    80
add action=dst-nat chain=dstnat comment="Nextcloud https" dst-address=\
    xxx.xxx.x51.94 dst-port=443 protocol=tcp to-addresses=192.168.0.2 \
    to-ports=443
/system clock
set time-zone-name=Europe/Zurich
/system identity
set name=RouterOS
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
/tool mac-server
/tool mac-server mac-winbox
(1) Why is dns server set at 192.168.0.2 for dhcp settings ??? ( vice the standard 192.168.0.1 ) ?
(2) The input chain rules can be modified but are not your problem recommend…
_/ip firewall filter
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
“defconf: accept to local loopback (for CAPsMAN)” dst-address=127._0.0.1
add action=accept chain=input in-interface=wireguard1 src-address=192.168.100.0/24
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
(3) Your hairpin nat rule is non-standard it should be… ( https://forum.mikrotik.com/viewtopic.php?t=179343 )
add action=masquerade chain=srcnat comment=“Hairpin NAT” dst-address=192.168.0.0/24 src-address=192.168.0.0/24
(4) You could also consider adding the wireguard interface to the LAN interface list as a member and in that regard you can remove the input chain firewall rule as it would be considered part of the LAN access provided by the last rule in the input chain.
The gateway address of your nas(192.168.0.2) is not ROS, right?
There are two gateways in your lan network, so this problem arises. There are actually two solutions,
None of these solutions are perfect, but they can solve your problem.
  1. Ros dst-nat to your other gateway, your other gateway dst-nat to nas.
  2. Add a src-dst in ros. chain=srcnat action=masquerade dst-address=“192.168.0.2”
  • 1 There may be another gateway in its network. It looks like this nas—>other(gateway1)—>MT(gateway2)
I guess when using MT to set up DST-NAT, data is flowing to MT through other gateways (perhaps doing a SRC-NAT). Will it cause this problem?
