Wireguard: how to access to SMB active on RouterOS?
Hi, I would like to access remotely and with wireguard to SMB sharing active on hAP ax3.
Once connected with Wireguard I can access to the entire hAP ax3 network, but not to the active sharing in the router.
Have I forgotten something in firewall?
Thanks for your help.
# feb/22/2023 16:19:38 by RouterOS 7.8rc3
# software id = BH9H-NUQS
# model = C53UiG+5HPaxD2HPaxD
# serial number = HDG08XXXXXX
/container mounts
add dst=/minidlna name=DLNA src=/usb1/containers/minidlna-data
add dst=/Film name="DLNA Media" src=/usb1/Dati/Film
add admin-mac=48:A9:8A:0E:18:EB auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .frequency=5180-5500 \
    .skip-dfs-channels=10min-cac .width=20/40/80mhz configuration.country=\
    Italy .mode=ap .ssid=MikroTik disabled=no security.authentication-types=\
    wpa2-psk .management-protection=disabled .wps=disable
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40mhz configuration.country=Italy .mode=ap .ssid=\
    MikroTik disabled=no security.authentication-types=wpa2-psk \
/interface veth
add address=192.168.10.3/24 gateway=192.168.10.1 name=veth1
/interface wireguard
add listen-port=31077 mtu=1420 name=wireguard1
/interface vlan
add interface=ether1 name=vlan835 vlan-id=835
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan835 name=pppoe-out1 \
    use-peer-dns=yes user=user
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.10.10-192.168.10.254
add add-arp=yes address-pool=default-dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/queue type
add kind=fq-codel name="fq codel"
/queue tree
add max-limit=295M name="FTTH Upload" packet-mark=no-mark parent=pppoe-out1 \
    queue="fq codel"
/container
add envlist=DLNA interface=veth1 mounts="DLNA,DLNA Media" root-dir=\
    usb1/containers/minidlna start-on-boot=yes
/container config
set registry-url=https://registry-1.docker.io tmpdir=/usb1/containers/tmp
/container envs
add key=MINIDLNA_MEDIA_DIR name=DLNA value=/Film
add key=MINIDLNA_FRIENDLY_NAME name=DLNA value="Router MikroTik"
add key=MINIDLNA_ROOT_CONTAINER name=DLNA value=B
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add bridge=bridge comment="minidlna container" interface=veth1
add comment="FTTH" interface=pppoe-out1 list=WAN
/interface wireguard peers
add allowed-address=172.20.1.2/32 interface=wireguard1 public-key=\
    "cut"
add address=192.168.10.1/24 comment=defconf interface=bridge network=\
    192.168.10.0
add address=172.20.1.1/24 comment=WireGuard interface=wireguard1 network=\
    172.20.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
/ip dhcp-server lease
add address=192.168.10.10 client-id=1:70:85:c2:62:34:b2 comment="PC" \
    mac-address=70:85:C2:62:34:B2 server=defconf
add address=192.168.10.0/24 comment=defconf dns-server=192.168.10.1 gateway=\
    192.168.10.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.10.1 comment=defconf name=router.lan
add action=accept chain=input comment="allow WireGuard" dst-port=31077 \
    protocol=udp
add action=accept chain=input comment="allow WireGuard traffic" src-address=\
    172.20.1.0/24
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ip smb
set allow-guests=no domain=WORKGROUP enabled=yes interfaces=bridge,wireguard1
/ip smb shares
add directory=usb1/Dati name=Router
/ip smb users
add name=smb read-only=no
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=pppoe-out1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/Rome
/system package update
set channel=testing
/tool e-mail
/tool mac-server
/tool mac-server mac-winbox
Good question, I have no idea what SMB is??
I dont see any thing in the firewall rules either way…
I prefer a drop all rule in the forward chain and removal of this rule
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
and replace it with better security focussed and clear rules…
add action=accept chain=forward comment=“internet traffic” in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward comment=“port forwarding” connection-nat-state=dstnat
add action=drop chain=forward comment=“drop all else”
Then for wireguard for example…
add action=accept chain=forward comment=internet in-interface-list=LAN out-interface-list=WAN
add action=accept chain=forward in-interface=wireguard1 out-interface=bridge { or perhaps to a specific server dst-address=IPofServer }
add action=accept chain=forward comment=P-forwarding connection-nat-state=dstnat
In this case is SMB an interface, an IP address a subnet, something indentifiable in a rule. ???
If its a layer2 construct you may be SOL, but then better off use zerotier for a Layer2, or multicast use case…
SMB is Samba WinBox IP → SMB
Sorry I didn’t explain well :unamused:
I confirm that with Zerotier the same configuration works perfectly, unfortunately clients must necessarily use wireguard.
Odd because SMB is supposed to work over TCP… if your TCP connection works, SMB should as well.
How did you try to access the share ? Using netname or IP address ? If the former, try the latter.
Odd for sure, especially since I clearly laid out a case that a firewall rule with, interface name, or IP ADDRESS, would be needed.
IP address.
Yes it’s odd because when I connect with wireguard I can connect to one NAS (IP 192.168.10.254) always with smb…
I can reach also all the router services (192.168.10.1) so I guess the problem is in the SMB configuration:
/ip smb
Or maybe it’s a 7.8rc bug…
OK with
/ip smb
set allow-guests=no domain=WORKGROUP enabled=yes interfaces=all
It works perfectly, but not it seems to me very safe :unamused:
Why not ? You’re behind a firewall and using vpn.
Concur with Hoelve, from the practical viewpoint, I am just sorry I dont have the technical acumen to explain why the ALL works and the other setting didnt… :frowning:
You’re right, I thought it was dangerous to expose smb on all interfaces, PPPoE included.
Thanks anyway, you’ve been very helpful.
I think I figured out why… wireguard1 interface IP is 172.20.1.1/24 and on log, when I set interfaces=all, there is
May be that SMB is expecting a connection from 172.20.1.1 and not 172.20.1.2?
Unless i missed something your wireguard interface is not part of LAN nor WAN ?
Can you set it to LAN ?
Nope. This shows the IP address of the connecting client, not of the SMB server (the router) itself.
If you can afford it temporarily, remove bridge from the list of interfaces in the SMB settings and try with wireguard1 alone. If that also works, it means that the version has a problem with handling a list of interfaces.
Sure!
Unfortunately smb is always not available…
OK, thank you!
Doesn’t work also with wireguard1 only, it works with “any” only…
I can also confirm that I’m unable to connect to ROS SMB share over Wireguard and wireguard interface is in SMB interface list.
For eg. OVPN client binding interfaces are also in SMB interface list and over OpenVPN connection works.
I have ip filter rule that accepts input for all VPN interfaces and connection to other ROS services (http, ssh, UPnP…) are working, but SMB on Wireguard not.
Thanks for the confirmation, I contacted support.
Hey, have you received any update from support? I’m experiencing the same problem.
Yes, they replied that:
Thank you for your report. We will try to find a root cause of this problem as soon as possible.
SUP-108546
Hello! Any news about this exact problem I also have?
hAP ax^3 with ROS 7.11.2
Hi, no nothing new… the ticket closed automatically and I don’t think they are thinking about resolving it.
I have the same problem, is there any development on the matter as of today?
