WireGuard : I am missing something
I have weird problem with WireGuard. As I am not posting configuration I guess I should explain status, just need idea what may be missing.
Network 172.18.111.0/24 is unattended, if I play to simplify something for example here I may lost access, that for need to be careful.
I do have two L2TP tunnels (two just as backup because both IP are dynamic)
Also, have created WireGuard to improve performance and this is working with one only problem :
Router 1 :
172.18.111.1/24
Router 2 :
172.18.127.1/24
when L2TP is disabled and WireGuard is active everything is working ok except routers itself.
172.18.127.5 ↔ 172.18.111.5 works fine
172.18.127.1 → anything in 172.18.111.0/24 is not working
172.18.111.1 → anything in 172.18.127.0/24 is not working
For testing purpose I have created lots of accept rules on both side, input/output/forward, even rules with no sense, but this is just not working from router itself.
I CAN connect from 172.18.127.55 to 172.18.111.1 (ping or winbox)
I just can not initiate connection from any of routers to another network and this is important because of dns forwarding and netwatch.
Any idea what may be wrong ?
Following exists on both side, again, 172.18.127.<anything but 1> is working with 172.18.111.<anything but 1>
(I know few of them make no sense, just testing)
add action=accept chain=input dst-address=172.18.127.0/24 src-address=172.18.111.0/24
add action=accept chain=forward dst-address=172.18.127.0/24 src-address=172.18.111.0/24
add action=accept chain=input dst-address=172.18.111.0/24 src-address=172.18.127.0/24
add action=accept chain=forward dst-address=172.18.111.0/24 src-address=172.18.127.0/24
add action=accept chain=input dst-address=172.18.127.1 src-address=172.18.111.1
add action=accept chain=forward dst-address=172.18.127.1 src-address=172.18.111.1
add action=accept chain=output dst-address=172.18.127.1 src-address=172.18.111.1
add action=accept chain=input dst-address=172.18.111.1 src-address=172.18.127.1
add action=accept chain=forward dst-address=172.18.111.1 src-address=172.18.127.1
add action=accept chain=output dst-address=172.18.111.1 src-address=172.18.127.1
add action=accept chain=input in-interface=WireGuardStgoBgd
add action=accept chain=output out-interface=WireGuardStgoBgd
add action=accept chain=forward in-interface=WireGuardStgoBgd
add action=accept chain=forward out-interface=WireGuardStgoBgd
