Hi there,
I am configuring my RouterBoard 3011.
The router already uses a wireguard interface as a client to use a paid VPN.
I would now like to configure a WireGuard server:
- I have added a WireGuard interface
- Then when I have to assign an IP address to this interface (10.0.0.1/24) , the new address is reported as invalid.
IP Addresses
https://imgur.com/a/ZoblOP5
What can this be due to?
Thank you in advance for the help!
Because there is a problem with the interface where you want to apply that address to.
That needs to be fixed first.
Best to export your config, edit on PC and remove serial / WAN IP / public keys /…
Then post back in between [__code] quotes for easier reading.
I just add a WireGuard interface without any parametrization, nothing other.
Something is wrong in any case with that interface.
You can already see it because the name is italic.
If I simply add another WG interface on my router, it immediately comes in Running state and no italic name.
What ROS version are you using ?
