Hello forum,
Unfortunately, I am now having a problem with Wireguard with RouterOS 7.21.3.
I can no longer establish a connection via IPv4.
I have a dual-stack WAN connection.
This means I have my own IPv4 and IPv6 addresses.
Both are dynamic and change every 24 hours.
To avoid having to remember the addresses, I have set up a dyndns.
I use Android smartphones with Android 16 as clients, for example.
When I try to establish a VPN connection with Wireguard via an IPv4-only network, it no longer works.
If I enter the current IPv6 address in the Wireguard address field and then connect, everything works fine.
I also don't see in the firewall log that a packet has arrived at the firewall via IPv4.
What I have checked:
- Domain entered as Wireguard server >> Doesn't work
- IPv4 entered as Wireguard server >> Doesn't work
- IPv6 entered as Wireguard server >> Works!
- Checked from the internet whether the Wireguard port is accessible >> Accessible with IPv4 and IPv6
- Checked the firewall rules >> Everything seems to be OK
- Router restarted >> Doesn’t help
No changes have been made to the settings since November 2025.
Only one client was added.
My ISP has not made any changes to the network either. I don't have DS-Light (GCNAT).
Why doesn't the domain work when it has both entries (A + AAAA)?
It seems that Android/Wireguard first receives the A record during DNS resolution and uses it directly.
The AAAA record is probably only delivered afterwards.
That's why the domain doesn't work when I enter both addresses.
Is there a known problem at the moment?
At the moment, it's a bit annoying to always have to query the current IPv6 via nslookup and then manually enter it in the configuration.
I can't use Wireguard from IPv4-only networks.
