I have a MT hAP ac3 at home, that I would like to use as a VPN as well. I have routerOS 7.1.1 and I would like to use WireGuard as it looks like the simplest and most performant solution. My ISP provides a public IP using PPPoe, and I was able to port forward other services from my network, but wireguard just don’t seem to be work for me. I included a network diagram for my setup, and my config. Thx for all the help!
# jan/30/2022 19:13:08 by RouterOS 7.1.1
# software id = 359J-7G3V
# model = RBD53iG-5HacD2HnD
add admin-mac=<hidden> auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac configuration.country=<hidden> .mode=ap .ssid=\
"<hidden>" disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac configuration.country=<hidden> .mode=ap .ssid=\
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 service-name=<hidden> use-peer-dns=yes user=\
<hidden>
/interface wireguard
add listen-port=13231 mtu=1420 name=wireguard1
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=10.111.111.200-10.111.111.253
add address-pool=dhcp interface=bridge name=defconf
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" disabled=yes disabled=yes name=zt1 port=9993
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
/interface detect-internet
set detect-interface-list=all
add interface=wireguard1 list=WAN
/interface wireguard peers
add comment="iPhone 11" endpoint-port=13231 interface=wireguard1 public-key=\
"<hidden>"
add comment="MacBook Pro 16" endpoint-port=13231 interface=wireguard1 public-key=\
"<hidden>"
add address=10.111.111.254/24 comment=defconf interface=bridge network=10.111.111.0
add address=172.16.16.1/24 interface=wireguard1 network=172.16.16.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=yes interface=ether1
add address=10.111.111.0/24 comment=defconf dns-server=10.111.111.254 domain=local gateway=10.111.111.254 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=10.111.111.254 comment=defconf name=router.lan
add action=accept chain=input comment="enable WireGuard" dst-port=13231 protocol=udp
add action=accept chain=input comment="defconf: accept established,related,untracked" connection-state=\
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=\
yes
add action=accept chain=forward comment="defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=dst-nat chain=dstnat dst-port=6881 in-interface=all-ppp protocol=tcp to-addresses=10.111.111.10 to-ports=6881
add action=dst-nat chain=dstnat dst-port=6881 in-interface=all-ppp protocol=udp to-addresses=10.111.111.10 to-ports=6881
add action=dst-nat chain=dstnat dst-port=13231 in-interface=all-ppp protocol=udp to-addresses=10.111.111.254 to-ports=13231
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www-ssl certificate=fullchain.pem_0
set api disabled=yes
set api-ssl disabled=yes
/ipv6 address
add address=::1 from-pool=<hidden> interface=bridge
/ipv6 dhcp-client
add interface=pppoe-out1 pool-name=digi request=address,prefix
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp \
src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/ipv6 nd
add advertise-dns=no interface=bridge ra-delay=0s ra-interval=3m-6m ra-lifetime=10m
/ipv6 nd prefix default
set preferred-lifetime=30m valid-lifetime=33m
/system clock
set time-zone-name=<hidden>
/system leds
set 0 disabled=yes
/system leds settings
set all-leds-off=after-1min
/system routerboard settings
set cpu-frequency=auto
/tool mac-server
/tool mac-server mac-winbox
