Hi Guys
New to Mikrotik but not to networking.
We have a new L009 which we need to configure with the below features;
Allow internet access - done.
Configure Vlans - done
Block intra-Vlan traffic - done
Allow management from WAN - done
Allow NAT from WAN to server on Vlan - done
Allow WIreguard VPN to connect to LAN and Vlans - Not done.
We can configure wireguard for access from an Apple Mac and the Wireguard client connects. We have NO traffic flows though. We cannot ping the bridge, the management interface, the Vlan gateways or an ssh server that is on one of the Vlans. The ssh server has full internet access btw.
I’ suspecting a firewall rule however we do have the below line in the config;
action=accept chain=forward comment=“test rule” connection-state=“” dst-address=192.168.88.0/24 dst-address-list=Vlans in-interface=“wireguard - MH Home” log=yes
The group ‘Vlans’ has 10.0.10.0, 10.0.20.0, 10.0.30.0 - all 24 bit. We cannot ping ANY of the vlan gateways either.
The apple Wireguard config includes AllowedIPs = 0.0.0.0/0 - when we run up Wireguard we seem to be routing ALL traffic to the L009 and we cannot ping anything, including 8.8.8.8. Anything connected to the L009 Lan or any Vlan can ping 8.8.8.8
Configs below. We’ve edited the public/private key info for obvious reasons. The L009 has a public interface on my own LAN (with an IP of 192.168.0.189).
We’ve disabled all rules in the firewall that drop or block anything (just for test purposes)
Wireguard client;
[Interface]
PrivateKey =
ListenPort = 51820
Address = 192.168.100.4/32
DNS = 1.1.1.1
[Peer]
PublicKey = Pzppppppppppppm6aCZioPGopDuXY27l/fgDc6RMrRo=
Endpoint = 192.168.0.189:13231
PersistentKeepalive = 10
L009 Config
# 2025-04-22 10:10:34 by RouterOS 7.16.1
# software id = TR2D-QJ5X
# model = L009UiGS
# serial number = <edit>
add comment=LAN-BR-VLAN10 name=LAN-BR-VLAN vlan-filtering=yes
add admin-mac=F4:1E:57:A6:22:6E auto-mac=no comment=defconf name=bridge vlan-filtering=yes
/interface wireguard
add comment="Remote VPN access" listen-port=13231 mtu=1420 name="wireguard - MH Home"
/interface vlan
add comment=vlan10 interface=LAN-BR-VLAN name=vlan10 vlan-id=10
add comment=Vlan20 interface=LAN-BR-VLAN name=vlan20 vlan-id=20
add comment=vlan30 interface=LAN-BR-VLAN name=vlan30 vlan-id=30
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment="vlan10 pool" name=dhcp_pool8 ranges=10.0.10.2-10.0.10.254
add comment="Vlan20 pool" name=dhcp_pool10 ranges=10.0.20.2-10.0.20.254
add comment="vlan30 pool" name=dhcp_pool11 ranges=10.0.30.2-10.0.30.254
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=dhcp_pool8 interface=vlan10 name=dhcp1
add address-pool=dhcp_pool10 interface=vlan20 name=dhcp2
add address-pool=dhcp_pool11 interface=vlan30 name=dhcp3
/port
set 0 name=serial0
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=LAN-BR-VLAN comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp1
set discover-interface-list=all lldp-med-net-policy-vlan=1
/interface bridge vlan
add bridge=LAN-BR-VLAN comment=vlan10 tagged=LAN-BR-VLAN,ether8 vlan-ids=10
add bridge=LAN-BR-VLAN comment=vlan20 tagged=LAN-BR-VLAN,ether8 vlan-ids=20
add bridge=LAN-BR-VLAN comment=vlan30 tagged=LAN-BR-VLAN,ether8 vlan-ids=30
/interface wireguard peers
add allowed-address=192.168.100.4/32 client-address=192.168.88.4/32 client-dns=1.1.1.1 comment="MH home" interface="wireguard - MH Home" name=MH-VPN public-key="OAWkmVOpppppppTiwN2S/1faJEapppppppgovZ3Xjmw="
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=10.0.10.1/24 comment=vlan10 interface=vlan10 network=10.0.10.0
add address=10.0.20.1/24 comment=vlan20 interface=vlan20 network=10.0.20.0
add address=10.0.30.1/24 comment=vlan30 interface=vlan30 network=10.0.30.0
add address=192.168.88.100/24 comment="Wireguard IP" interface="wireguard - MH Home" network=192.168.88.0
add address=172.30.99.1/24 interface=ether2 network=172.30.99.0
/ip cloud advanced
set use-local-address=yes
/ip dhcp-client
add address=10.0.10.0/24 gateway=10.0.10.1
add address=10.0.20.0/24 comment="Vlan 10 Network" dns-server=8.8.8.8,8.8.4.4 gateway=10.0.20.1 netmask=24
add address=10.0.30.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=10.0.30.1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=10.0.10.0/24 comment="Vlan 10" list=Vlans
add address=10.0.20.0/24 comment=Vlan-20 list=Vlans
add address=10.0.30.0/24 comment=Alan-30 list=Vlans
add address=10.0.20.0 comment=10.0.20.0 list=10.0.20.0
add action=accept chain=forward comment="test rule" connection-state="" dst-address=192.168.88.0/24 dst-address-list=Vlans in-interface="wireguard - MH Home" log=yes
add action=accept chain=input comment="remote admin" dst-port=80 protocol=tcp src-address=192.168.0.0/24
add action=accept chain=input comment="fireguard rule" dst-port=13231 protocol=udp
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new disabled=yes in-interface-list=WAN
add action=dst-nat chain=dstnat comment="NAT to Pi" dst-address=192.168.0.189 dst-port=22 protocol=tcp to-addresses=10.0.30.12 to-ports=22
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/London
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
/tool mac-server
/tool mac-server mac-winbox
