I was setting up my three routers (all RB4011iGS+5HacQ2HnD) up with ROS7 from scratch. I started with the IP settings (IP address and DHCP server) and then configured CAPsMAN which worked as expected for my access points (all set up in CAPS mode) and the local wifi of the router. After that I set up WireGuard by following the RoadWarrior WireGuard tunnel documentation.
On the first two devices I just discovered at the end that CAPsMAN wasn’t working anymore for the router (local access through 127.0.0.1) and I wasn’t able to fix it which forced me to set up wifi manually on the router. On the third device I checked a bit more closely and discovered that the local CAPsMAN connection starts failing just after adding the wireguard interface and before any firewall or interface list changes.
I was starting with 7.10.2 and hoping that 7.11 maybe fixes the issue but I tested it this morning and the issue remains.
Here’s the configuration of the third router I set up yesterday: wireguard_capsman_issue.txt (8.86 KB)
Is this a known issue (I couldn’t find anything using search)? Is there anything additional I can check/log to pin down the issue? Or is it just some misconfiguration on my end?
Thanks a lot for taking the time to answer, it’s very appreciated!
I am, I just exported the config before I updated. Unfortunately 7.11 doesn’t change anything for me on that issue.
To me it’s very helpful as I don’t have to configure 3 access points but only once at a central place.
Yes, I messed up when I adjusted the configuration before attaching it here. I’m using 192.168.8.0 for the local network and 192.168.88.0 for the WireGuard peers, so I manually changed it to 192.168.9.0 and 192.168.99.0 to not confuse you with the default 192.168.88.0. This setting you mention is actually 192.168.9.1 but I’m using the ISPs dns.
I just disabled it but local CAP still doesn’t connect.
I think your config missing following:
/interface wireless cap set caps-man-addresses=127.0.0.1
Your config already contains:
add action=accept chain=input comment=
I would propopose 1 more for output:
/ip firewall filter add chain=output action=accept protocol=udp src-address=127.0.0.1 dst-address=127.0.0.1 port=5246,5247
/ip firewall filter add chain=input action=accept protocol=udp src-address=127.0.0.1 dst-address=127.0.0.1 port=5246,5247
These settings are only for 4011 with local cap.
All remote CAPs leave as is.
I just compared your config vs my hap ac3 with capsman + local cap
Your config:
set bridge=bridge discovery-interfaces=bridge interfaces=wlan1,wlan2
My config:
set bridge=bridge1 caps-man-addresses=127.0.0.1 enabled=yes interfaces=wlan1
PS - my config runs as wireguard client with no problems
PS2 - you may disable this for 4011+local CAP:
add bridge=bridge comment=defconf interface=wlan2
wlan1 and wlan2 will be added dynamically upon you enable CAP mode , as you specify bridge:
Try it up (7.10-7.11 works with no changes)
Awesome, you’re my hero! this was the missing piece. You made my day, thanks a lot!
It’s interesting that the local CAPsMAN can be discovered without that setting if no WireGuard is present but is needed with WireGuard active. Is this something we need to inform Mikrotik about?
